- To: Jason Gross <jasongross9 AT gmail.com>
- Cc: Leonardo de Moura <leonardo AT microsoft.com>, "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] coercing equality proofs
- Date: Tue, 28 Jan 2014 15:50:19 -0500
It should be possible to do using the "bracket type" projection Type -> Prop but I am not sure how exactly it works in Coq since I do not use Prop.
V.
On Jan 28, 2014, at 2:30 PM, Jason Gross <jasongross9 AT gmail.com> wrote:
There is no way without axioms. Going the other way is straightforwad: "match (H : @eq Prop x y) in (_ = y') return (@eq Type x y') with eq_refl => eq_refl end". It does not work going the other way because y' would be a Type, and you'd be trying to make it a Prop. If you think about this homotopy-theoretically (google homotopy type theory), there is no guarantee that every point along a path @eq Type_i (x : Type_j) (y : Type_j) will be small enough to fit into a Type_j. You could do it with Axiom K, I believe.
-Jason
On Jan 28, 2014 1:06 PM, "Leonardo de Moura" <leonardo AT microsoft.com> wrote:Hi,
Given (x y : Prop), I’m wondering about how to coerce an equality proof for (@eq Type x y) to (@eq Prop x y).
Is this possible?
Thanks,
Leo
- [Coq-Club] coercing equality proofs, Leonardo de Moura, 01/28/2014
- Re: [Coq-Club] coercing equality proofs, Jason Gross, 01/28/2014
- Re: [Coq-Club] coercing equality proofs, Vladimir Voevodsky, 01/28/2014
- Re: [Coq-Club] coercing equality proofs, Jeremy Avigad, 01/28/2014
- Re: [Coq-Club] coercing equality proofs, Cody Roux, 01/28/2014
- Re: [Coq-Club] coercing equality proofs, Bas Spitters, 01/29/2014
- Re: [Coq-Club] coercing equality proofs, Arnaud Spiwack, 01/29/2014
