coq-club - Re: [Coq-Club] coercing equality proofs
  • To: Vladimir Voevodsky <vladimir AT ias.edu>
  • Cc: Jeremy Avigad <avigad AT cmu.edu>, Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] coercing equality proofs
  • Date: Wed, 29 Jan 2014 00:01:45 +0100
That's done in this paper:
http://arxiv.org/abs/1309.5767
On Tue, Jan 28, 2014 at 11:32 PM, Vladimir Voevodsky
wrote:
> There is another way to define bracket in Coq. Something like that:
> Inductive bracket ( A : Type ) : Prop := wit : A -> bracket A .
> V.
> On Jan 28, 2014, at 4:45 PM, Jeremy Avigad
> <avigad AT cmu.edu>
> wrote:
> It should be possible to do using the "bracket type" projection Type -> Prop
> but I am not sure how exactly it works in Coq since I do not use Prop.
> V.
> Good point. Here is how to do it using propositional extensionality.
> (Sorry for the lousy proof scripts. I have been away from Coq for a while.)
> Best wishes,
> Jeremy
> Axiom prop_ext: forall (p q : Prop), (p <-> q) -> p = q.
> Section Test.
> Variables a b : Prop.
> Variable p : @eq Type a b.
> Definition bracket (A : Type) : Prop := forall (P : Prop), (A -> P) -> P.
> Lemma bracket_eq (x : Prop): bracket x = x.
> apply prop_ext.
> split.
> intro H.
> apply (H x).
> intro H1. apply H1.
> intros H P H1.
> apply (H1 H).
> Qed.
> Lemma coerce: @eq Prop a b.
> transitivity (bracket a).
> symmetry. apply bracket_eq.
> transitivity (bracket b).
> rewrite p. reflexivity.
> apply bracket_eq.
> Qed.
> End Test.
> V.
> On Jan 28, 2014, at 2:30 PM, Jason Gross
> <jasongross9 AT gmail.com>
> wrote:
> There is no way without axioms. Going the other way is straightforwad:
> "match (H : @eq Prop x y) in (_ = y') return (@eq Type x y') with eq_refl =>
> eq_refl end". It does not work going the other way because y' would be a
> Type, and you'd be trying to make it a Prop. If you think about this
> homotopy-theoretically (google homotopy type theory), there is no guarantee
> that every point along a path @eq Type_i (x : Type_j) (y : Type_j) will be
> small enough to fit into a Type_j. You could do it with Axiom K, I believe.
> -Jason
> On Jan 28, 2014 1:06 PM, "Leonardo de Moura"
> <leonardo AT microsoft.com>
> wrote:
>> Hi,
>> Given (x y : Prop), I'm wondering about how to coerce an equality proof
>> for (@eq Type x y) to (@eq Prop x y).
>> Is this possible?
>> Thanks,
>> Leo
