- From: Gabriel Scherer <gabriel.scherer AT gmail.com>
- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Erasable Red/Black Trees in Coq
- Date: Tue, 22 Apr 2014 09:18:27 +0200
The usual style for "code that extracts to what you expect" is to implement the algorithm on the plain, "weakly typed" data structure that you would use in ML, and prove after-the-fact that the invariants hold in a separate lemma. This approach produces code that is "trivially erasable", because after you forget about the lemmas you just have (strongly terminating) ML code written in Gallina syntax.
If I understand correctly, you made two different, orthogonal decisions:On Mon, Apr 21, 2014 at 9:02 PM, Jonathan <jonikelee AT gmail.com> wrote:
To all,
If you're interested in a way to get full erasability in Coq, or yet another encoding of Red/Black trees in Coq, have a look at:
https://github.com/jonleivent/mindless-coding
Erasability is accomplished by adding a single injectivity axiom to a single wrapper Prop type (Erasable). The readme explains things, and the Coq file is fairly well commented.
Any comments and/or criticisms are welcome!
-- Jonathan
- [Coq-Club] Erasable Red/Black Trees in Coq, Jonathan, 04/21/2014
- Re: [Coq-Club] Erasable Red/Black Trees in Coq, Gabriel Scherer, 04/22/2014
- Re: [Coq-Club] Erasable Red/Black Trees in Coq, Cedric Auger, 04/22/2014
- Re: [Coq-Club] Erasable Red/Black Trees in Coq, Jonathan, 04/22/2014
- Re: [Coq-Club] Erasable Red/Black Trees in Coq, Arnaud Spiwack, 04/22/2014
- Re: [Coq-Club] Erasable Red/Black Trees in Coq, Jonathan, 04/23/2014
- Re: [Coq-Club] Erasable Red/Black Trees in Coq, AUGER Cédric, 04/23/2014
- Re: [Coq-Club] Erasable Red/Black Trees in Coq, Arnaud Spiwack, 04/23/2014
