coq-club - Re: [Coq-Club] Erasable Red/Black Trees in Coq
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Erasable Red/Black Trees in Coq
  • Date: Tue, 22 Apr 2014 18:45:59 -0400
On 04/22/2014 01:52 PM, Arnaud Spiwack wrote:
I tried using "difflists" - which are the list implementation of this
idea, and it did not work. There were two ways I tried using it. The
first was to use difflists as a complete replacement for lists. This
failed to work because of requirements for lemmas such as sortedr, which
states:
forall x y, sorted (x ++ y) -> sorted y.
If x is a difflist, then it is really just a function mapping (normal)
lists to lists, and append is just a type of function composition.
However, consider the function reverse, which is also a function mapping
lists to lists - obviously, the above lemma is false if x is the reverse
function.
An alternative hybrid use of difflist that I tried was to have just the
append operator itself be difflist-based, while the rest of the lists are
normal lists, with the addition of implicit coercion. This did not work
either, but it is more difficult to explain why.
Indeed, this is why you need (conversion level) proof irrelevance: you need
to restrict to the type of functions from lists to lists which are of the
form (λy. l++y) for some list l. Associative laws will be up to conversion
only if the proof (essentially the list l) is irrelevant to the conversion.
/Arnaud Spiwack
But, can this be made to work in Coq, where there is no built-in irrelevance of any kind?
-- Jonathan
