- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Erasable Red/Black Trees in Coq
- Date: Tue, 22 Apr 2014 10:45:06 -0400
On 04/22/2014 04:04 AM, Arnaud Spiwack wrote:
Dear Jonathan,
This is a nice example. Note that this precise idea has been explored
before (see for instance
http://www.pps.univ-paris-diderot.fr/~letouzey/download/Letouzey_Spitters_05.pdf).
Thank you very much for that link! I was not aware of this.
As you elegantly notice, there is a use for a proof relevant (so that you
can discriminate between annotations) yet static/erasable sort. Erasing
proof irrelevant things is, by the way, one of the key points of Edwin
Brady's thesis (see for instance [
http://eb.host.cs.st-andrews.ac.uk/writings/types2003.pdf ]).
I have had some communications with developers of Idris who are working on an implementation of erasability there. But, I should read Edwin's thesis at some point. I am somewhat familiar with the paper you link above. One of the things that I hope to point out is that Coq's separation of Prop from Set and Type does not entail the requirement for code duplication in order to get an effective erasure of all proof-related terms. For example, I did not duplicate list or nat in rbtree.v.
For unification/conversion up to monoid laws, there is a solution which
uses proof irrelevance in conversion (!). It's been found by Alan Jeffrey
in Agda [ https://lists.chalmers.se/pipermail/agda/2011/003420.html ]. The
idea is that every monoid is a submonoid of a function monoid (with
identity and composition). This is a classic result, a variant of Cayley's
theorem [ http://en.wikipedia.org/wiki/Cayley%27s_theorem ]: specifically
for a monoid M, it is a submonoid of the functions M⟶M, each element x
being interpreted as (λy. x⋆y). The above link contains the details, but
this lemma allows to turn any monoid in a monoid where associativity is up
to conversion (provided we have a way to do some conversion level proof
irrelevance like in Agda).
I tried using "difflists" - which are the list implementation of this idea, and it did not work. There were two ways I tried using it. The first was to use difflists as a complete replacement for lists. This failed to work because of requirements for lemmas such as sortedr, which states:
forall x y, sorted (x ++ y) -> sorted y.
If x is a difflist, then it is really just a function mapping (normal) lists to lists, and append is just a type of function composition. However, consider the function reverse, which is also a function mapping lists to lists - obviously, the above lemma is false if x is the reverse function.
An alternative hybrid use of difflist that I tried was to have just the append operator itself be difflist-based, while the rest of the lists are normal lists, with the addition of implicit coercion. This did not work either, but it is more difficult to explain why.
Another tool is Pierre-Yves Strub CoqMT [
http://pierre-yves.strub.nu/coqmt/], which allows to plug in decision
procedures inside the conversion of Coq
(the current prototype has Presburger's arithmetic if I'm not mistaken).
This looks very promising! Thanks for this link as well!
-- Jonathan
- [Coq-Club] Erasable Red/Black Trees in Coq, Jonathan, 04/21/2014
- Re: [Coq-Club] Erasable Red/Black Trees in Coq, Gabriel Scherer, 04/22/2014
- Re: [Coq-Club] Erasable Red/Black Trees in Coq, Cedric Auger, 04/22/2014
- Re: [Coq-Club] Erasable Red/Black Trees in Coq, Jonathan, 04/22/2014
- Re: [Coq-Club] Erasable Red/Black Trees in Coq, Arnaud Spiwack, 04/22/2014
- Re: [Coq-Club] Erasable Red/Black Trees in Coq, Jonathan, 04/23/2014
- Re: [Coq-Club] Erasable Red/Black Trees in Coq, AUGER Cédric, 04/23/2014
- Re: [Coq-Club] Erasable Red/Black Trees in Coq, Arnaud Spiwack, 04/23/2014
- Re: [Coq-Club] Erasable Red/Black Trees in Coq, Arnaud Spiwack, 04/24/2014
- Re: [Coq-Club] Erasable Red/Black Trees in Coq, Jonathan, 04/24/2014
