- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Erasable Red/Black Trees in Coq
- Date: Tue, 22 Apr 2014 10:11:32 -0400
On 04/22/2014 03:18 AM, Gabriel Scherer wrote:
The usual style for "code that extracts to what you expect" is to implement
the algorithm on the plain, "weakly typed" data structure that you would
use in ML, and prove after-the-fact that the invariants hold in a separate
lemma. This approach produces code that is "trivially erasable", because
after you forget about the lemmas you just have (strongly terminating) ML
code written in Gallina syntax.
If I understand correctly, you made two different, orthogonal decisions:
1) you encode logical invariants directly in the data-structure
declaration: one of the indices of the "rbtree" inductive is a list of its
elements (that is, its semantics), and the constructors expect proofs that
this list is sorted -- and you are careful to have this proof in Prop for
erasability
2) you wrote all the algorithmic content not as programs, but as proof
scripts using tactics, so that the various functions pass as "theorems"
whose extraction returns the initial algorithm
Could you comment on why you made those choices? My (relatively limited)
personal experience would rather indicate that (1) is not the most
practical way to write software as of today (although it's an interesting
design option that should be made as practical as possible by improvement
to Gallina, in particular allowing tactic scripts as subparts of programs),
and that (2) is a bad idea, as it makes code harder to both write and read.
An argument in favor of (1) would be that, as most after-the-fact
correctness proof in fact follow the structure of the code (or conversely
that most implementations are performed in the order natural to also prove
them correct), doing the implementation and the proof at the same time
would avoid some repeated structure and thus might result in shorter
developments. Was this a goal of your approach?
I've seen others address the difference between "classical" after-the-fact proofs of code and the more internal style enabled by dependenty-typed programming languages. One of the arguments is as you suggest - after-the-fact proofs have to do considerable work just to follow the structure of the code. Another reason I used this approach, as well as implemented functions in Coq using proof scripts, was to benefit from the type-checker's feedback after every implementation step. In Agda and Idris, two other dependently-typed languages, that feedback can be experienced while using program constructs - but this is not (yet?) true about Coq. I did try using Coq's Program construct, which allows the programmer to first establish a skeletal implementation using programming constructs, then respond separately to proof obligations it generates. However, I could not always get Program to do what I wanted, and often ended up with unprovable obligations. Also, use of Program removes (by design) some of the interaction with the type checker.
I think that the proof-script style of coding obscures what is going on in rbtree.v. But, the choices of Coq (for Prop) and then proof scripts (for interactive type-checking-driven development of functions) were both very enabling in their ways. It could even be argued that the unusual proof-script programming style helps to establish the point that once the data structures and return types are fully constrained, the implementation task itself doesn't need to have much attention paid to the algorithms being implemented, but instead can focus on the much smaller goals provided to the programmer by the type checker as the implementation of each function is incrementally built.
-- Jonathan
- [Coq-Club] Erasable Red/Black Trees in Coq, Jonathan, 04/21/2014
- Re: [Coq-Club] Erasable Red/Black Trees in Coq, Gabriel Scherer, 04/22/2014
- Re: [Coq-Club] Erasable Red/Black Trees in Coq, Cedric Auger, 04/22/2014
- Re: [Coq-Club] Erasable Red/Black Trees in Coq, Jonathan, 04/22/2014
- Re: [Coq-Club] Erasable Red/Black Trees in Coq, Arnaud Spiwack, 04/22/2014
- Re: [Coq-Club] Erasable Red/Black Trees in Coq, Jonathan, 04/23/2014
- Re: [Coq-Club] Erasable Red/Black Trees in Coq, AUGER Cédric, 04/23/2014
- Re: [Coq-Club] Erasable Red/Black Trees in Coq, Arnaud Spiwack, 04/23/2014
- Re: [Coq-Club] Erasable Red/Black Trees in Coq, Arnaud Spiwack, 04/24/2014
- Re: [Coq-Club] Erasable Red/Black Trees in Coq, Jonathan, 04/24/2014
