- To: coq-club <coq-club AT inria.fr>
- Cc: "coqdev AT inria.fr" <coqdev AT inria.fr>
- Subject: Re: [Coq-Club] Tactic for detecting that there is a goal left?
- Date: Fri, 13 Jun 2014 16:23:51 +0100
I was hoping to avoid needing to run the preceding tactic twice, or even needing to know what it is.
On Fri, Jun 13, 2014 at 4:19 PM, Adam Chlipala <adamc AT csail.mit.edu> wrote:
Just use an "||" composition of your two tactics, for "no goals left" and "exactly one goal left". Admittedly, it's too bad to need to run the preceding tactic twice in some cases.
On 06/13/2014 11:16 AM, Jason Gross wrote:
Actually, my [at_most_one_goal_left] tactic doesn't work. Is there a way to detect "zero or one goals"?
On Fri, Jun 13, 2014 at 4:11 PM, Jason Gross <jasongross9 AT gmail.com> wrote:
Hi,Is there a standard way of asking the question "are all goals solved?" and "is there at most one goal left?" in Ltac?
I can use "; solve [ idtac ]" to mean "fail if there are any goals left", and I have been using "; []" to detect "exactly one goal left", and and I can define a tactic
Ltac at_most_one_goal_left := idtac; [].
so that "; at_most_one_goal_left" will fail if there is more than one goal. But is seems poor that inlining a tactic definition changes its behavior; am I simply exploiting a bug?
-Jason
- [Coq-Club] Tactic for detecting that there is a goal left?, Jason Gross, 06/13/2014
- Re: [Coq-Club] Tactic for detecting that there is a goal left?, Jason Gross, 06/13/2014
- Re: [Coq-Club] Tactic for detecting that there is a goal left?, Adam Chlipala, 06/13/2014
- Re: [Coq-Club] Tactic for detecting that there is a goal left?, Jonathan, 06/13/2014
- Re: [Coq-Club] Tactic for detecting that there is a goal left?, Cedric Auger, 06/13/2014
- Re: [Coq-Club] [coqdev] Tactic for detecting that there is a goal left?, Arnaud Spiwack, 06/13/2014
- Re: [Coq-Club] [coqdev] Tactic for detecting that there is a goal left?, Jason Gross, 06/13/2014
- Re: [Coq-Club] [coqdev] Tactic for detecting that there is a goal left?, Jonathan, 06/13/2014
