- To: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Tactic for detecting that there is a goal left?
- Date: Fri, 13 Jun 2014 16:34:22 +0100
It doesn't actually work for the same reason "idtac; []" doesn't work; it fails with "Not enough subgoals" if you have no goals left. The "bug" is that some things, like square brackets, have special behavior with respect to semicolons, which are lost if you stick them inside a tactic.
-Jason
On Fri, Jun 13, 2014 at 4:31 PM, Jonathan <jonikelee AT gmail.com> wrote:
On 06/13/2014 11:25 AM, Jonathan wrote:Oh - that doesn't work when defined as a tactic, but does if it's inlined. Weird. How can that not be a bug?
How about:
idtac; [idtac|fail..].
On 06/13/2014 11:16 AM, Jason Gross wrote:
Actually, my [at_most_one_goal_left] tactic doesn't work. Is there a way
to detect "zero or one goals"?
On Fri, Jun 13, 2014 at 4:11 PM, Jason Gross <jasongross9 AT gmail.com> wrote:
Hi,
Is there a standard way of asking the question "are all goals solved?" and
"is there at most one goal left?" in Ltac?
I can use "; solve [ idtac ]" to mean "fail if there are any goals left",
and I have been using "; []" to detect "exactly one goal left", and and I
can define a tactic
Ltac at_most_one_goal_left := idtac; [].
so that "; at_most_one_goal_left" will fail if there is more than one
goal. But is seems poor that inlining a tactic definition changes its
behavior; am I simply exploiting a bug?
-Jason
- [Coq-Club] Tactic for detecting that there is a goal left?, Jason Gross, 06/13/2014
- Re: [Coq-Club] Tactic for detecting that there is a goal left?, Jason Gross, 06/13/2014
- Re: [Coq-Club] Tactic for detecting that there is a goal left?, Adam Chlipala, 06/13/2014
- Re: [Coq-Club] Tactic for detecting that there is a goal left?, Jonathan, 06/13/2014
- Re: [Coq-Club] Tactic for detecting that there is a goal left?, Cedric Auger, 06/13/2014
- Re: [Coq-Club] [coqdev] Tactic for detecting that there is a goal left?, Arnaud Spiwack, 06/13/2014
- Re: [Coq-Club] [coqdev] Tactic for detecting that there is a goal left?, Jason Gross, 06/13/2014
- Re: [Coq-Club] [coqdev] Tactic for detecting that there is a goal left?, Jonathan, 06/13/2014
- Re: [Coq-Club] [coqdev] Tactic for detecting that there is a goal left?, Arnaud Spiwack, 06/17/2014
