[Coq-Club] Existential Instantiation and the relationship between classical and constructive logic.
- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: [Coq-Club] Existential Instantiation and the relationship between classical and constructive logic.
- Date: Wed, 25 Jun 2014 14:17:33 -0400
I've been working on a problem in which, given some predicate, P : A -> Prop, I can prove that there exists some value, x : A, that satisfies P (I.E. P x).
This development occurred within the context of a module and I wanted to say something like: "There exists a value x : A, such that P x. ... Let K represent a value that satisfies P (we know that K exists because...). ...". The second part of this statement is an instance of existential instantiation.
In Gallina, it is possible to represent existential instantiation, it corresponds to ex's inductive property (ex_ind : forall (A : Type) (P : A -> Prop) (P0 : Prop), (forall x : A, P x -> P0) -> ex P -> P0). Specifically, the existentially quantified variable x is instantiated in P0's context ("forall x : A, P x -> P0"). My problem was that I wanted to instantiate an existentially quantified variable at the global level and use the variable in subsequent calculations.
Ex's definition seemed to prohibit me from doing this. So I changed the return type in ex's definition from Prop to Type producing:
Inductive ex2 (A : Type) (P : A -> Prop) : Type :=
ex2_intro : forall x : A, P x -> ex2 P.
Unlike ex's definition this new definition gives a recursive property:
ex2_rec : forall (A : Type) (P : A -> Prop) (P0 : ex2 P -> Set), (forall (x : A) (p : P x), P0 (ex2_intro P x p)) -> forall e : ex2 P, P0 e.
I was then able to define an existential instantiation operator as:
Definition ei (H : ex2 P) : sig P :=
ex2_rec (fun _ => sig P)
(fun (x : A) (H0 : P x) => exist P x H0) (* using a local existential instantiation to construct a set value. *)
H.
I could then use the existential operator to instantiate values that I can prove exist and satisfy certain constraints:
Parameter A : Set.
Parameter P : A -> Prop.
Axiom existence_axiom : ex2 P.
Definition a : sig P := ei existence_axiom.
I suspect that the ability to define values, by proving their existence rather than by "constructing" them, is essentially what distinguishes classical and constructive mathematics, but I'm not sure.
I have two questions. First, why is ex restricted to propositions? That is, Why doesn't ex have a recursive property? Second, is there an operation in the standard library that would allow me to instantiate existentially quantified variables at the global level without having to define my own constructs ex2 and ei?
Thanks for any insight, references, etc, that you all may be able to provide.
- Larry
- [Coq-Club] Remove or update a canonical structure registration?, Peng Wang, 06/18/2014
- Re: [Coq-Club] Remove or update a canonical structure registration?, Beta Ziliani, 06/18/2014
- Re: [Coq-Club] Remove or update a canonical structure registration?, Pierre-Marie Pédrot, 06/18/2014
- Re: [Coq-Club] Remove or update a canonical structure registration?, Strub, Pierre-Yves, 06/23/2014
- Re: [Coq-Club] Remove or update a canonical structure registration?, Peng Wang, 06/25/2014
- Message not available
- [Coq-Club] Existential Instantiation and the relationship between classical and constructive logic., Larry D. Lee jr., 06/25/2014
