- From: Christoph-Simon Senjak <christoph.senjak AT ifi.lmu.de>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Extraction fails
- Date: Fri, 27 Jun 2014 01:01:36 +0200
Thank you for the immediate answer.
> Are you suggesting that this failure occurs even when you don't have any
> "Extraction Implicit" declarations?
Yes, I do not use Extraction Implicit. Is that wrong?
If so, I have to say that I use a git-version. Might this be a bug in
that version?
> I have a project which uses extraction, and works around the inability
> of "Extraction Implicit" to deal with certain issues - collectively
> referred to as erasability. If you are interested:
> https://github.com/jonleivent/mindless-coding.
> -- Jonathan
- [Coq-Club] Extraction fails, Christoph-Simon Senjak, 06/27/2014
- Re: [Coq-Club] Extraction fails, Jonathan, 06/27/2014
- Re: [Coq-Club] Extraction fails, Christoph-Simon Senjak, 06/27/2014
- Re: [Coq-Club] Extraction fails, Greg Morrisett, 06/27/2014
- Re: [Coq-Club] Extraction fails, Jason Gross, 06/27/2014
