- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Extraction fails
- Date: Thu, 26 Jun 2014 16:15:42 -0700
Extraction Implicit is broken in the default Coq, when you use functors or
sealed modules. I think it's fixed in the trunk.
-Greg
> On Jun 26, 2014, at 4:07 PM, Jonathan
> <jonikelee AT gmail.com>
> wrote:
>> On 06/26/2014 07:01 PM, Christoph-Simon Senjak wrote:
>> Thank you for the immediate answer.
>>> Are you suggesting that this failure occurs even when you don't have any
>>> "Extraction Implicit" declarations?
>> Yes, I do not use Extraction Implicit. Is that wrong?
>> If so, I have to say that I use a git-version. Might this be a bug in
>> that version?
> It sounds like there is an "Extraction Implicit" declaration in something
> you are using. If you can identify the modules you are requiring, can you
> search in their sources for "Extraction Implicit"?
> I personally have not seen the "Extraction Implicit" error message occur
> without myself using an "Extraction Implicit" declaration, so that is my
> guess of what is happening with your project. But, it could always be a
> bug - if there are no "Extraction Implicit" declarations in any modules you
> are using, and you still get that error message, I would encourage you to
> send that into the Coq bug list.
> -- Jonathan
- [Coq-Club] Extraction fails, Christoph-Simon Senjak, 06/27/2014
- Re: [Coq-Club] Extraction fails, Jonathan, 06/27/2014
- Re: [Coq-Club] Extraction fails, Christoph-Simon Senjak, 06/27/2014
- Re: [Coq-Club] Extraction fails, Greg Morrisett, 06/27/2014
- Re: [Coq-Club] Extraction fails, Jason Gross, 06/27/2014
