- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Extraction fails
- Date: Thu, 26 Jun 2014 19:07:17 -0400
On 06/26/2014 07:01 PM, Christoph-Simon Senjak wrote:
Thank you for the immediate answer.
Are you suggesting that this failure occurs even when you don't have anyYes, I do not use Extraction Implicit. Is that wrong?
"Extraction Implicit" declarations?
If so, I have to say that I use a git-version. Might this be a bug in
that version?
It sounds like there is an "Extraction Implicit" declaration in something you are using. If you can identify the modules you are requiring, can you search in their sources for "Extraction Implicit"?
I personally have not seen the "Extraction Implicit" error message occur without myself using an "Extraction Implicit" declaration, so that is my guess of what is happening with your project. But, it could always be a bug - if there are no "Extraction Implicit" declarations in any modules you are using, and you still get that error message, I would encourage you to send that into the Coq bug list.
-- Jonathan
- [Coq-Club] Extraction fails, Christoph-Simon Senjak, 06/27/2014
- Re: [Coq-Club] Extraction fails, Jonathan, 06/27/2014
- Re: [Coq-Club] Extraction fails, Christoph-Simon Senjak, 06/27/2014
- Re: [Coq-Club] Extraction fails, Greg Morrisett, 06/27/2014
- Re: [Coq-Club] Extraction fails, Jason Gross, 06/27/2014
