- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.)
- Date: Tue, 22 Jul 2014 16:43:05 -0400
On 07/22/2014 02:33 PM, Jason Gross wrote:
I haven't really looked at the code carefully, but, a few comments:
- You can use [constructor] rather than [tauto] in [smuggler] to prove your
[JMeq] (however, note that using JMeq sets you up for contradicting
univalence; the only way to get from JMeq to eq is by assuming that the
universe is a set)
Note that I originally tried normal =, and it worked so long as I used destruct in smuggler instead of case - but the resulting equalities were just as unusable in the result (also, rewriting the result failed - as with the final rewrite or_false_r in logicalize). I decided to use JMeq instead because it seemed to get further, but still hits a wall. Dropping all equality works - but then one loses ability to tie the generated hypothesis back to the original one.
- You might want to use [cbv beta in <hypothesis>] to get rid of all the
function applications.
If you mean on the output hypothesis of logicalize, cbv beta does nothing. I have been composing some rewrite rules to get rid of the extraneous stuff - although it might be easier if doexistify was smarter about not over-complicating things, and if smuggler tried to eliminate false branches (either by using inversion, or proving a contradiction itself).
- Your first example fails for me in Coq 8.4pl4 with
Toplevel input, characters 0-12:
In nested Ltac calls to "logicalize" and
"instantiate ( 1 := False ) in (Value of P)" (expanded to
"instantiate ( 1 := False ) in (Value of P_)"), last call failed.
Error: Instantiate called on already-defined evar
Sorry, I'm using a trunk version. I am addicted to its evar backtracking abilities.
- To answer your comment about the failure, if you [Set Printing Implicit],
you'll notice that the type of [y] is [Y (S m) (S n)], but the type of [Y3
(S m)] is [Y (S m) 3]. So you first need to extract the fact that [n = 3]
(you should be able to do this without any axioms), use that to get rid of
[n], and then you can use [JMeq_eq] in the hypothesis.
-Jason
I haven't been able to get it to work. For instance, after Focus 3, inversion y0 produces
H1 : Y (S m) (S n) = Y (S m) 3, but using that to rewrite y dies with:
Toplevel input, characters 7-23:
Error: Cannot instantiate metavariable P of type "Type -> Prop" with
abstraction "fun T : Type => T" of incompatible type
"Type -> Type".
On Tue, Jul 22, 2014 at 3:04 PM, Jonathan
<jonikelee AT gmail.com>
wrote:
Attached is a first attempt at a general-purpose "Prop smuggling" tactic:
logicalize. The point is to take a Prop hypothesis and "invert" it even
when the current context is not Prop - producing a disjunction of exists
terms, one for each constructor.
However, the JMeq's don't work in the result, as demonstrated in the
second test. Can anyone figure out what's going wrong? If not, they can
just be omitted.
Also needed is a way to simplify out false cases and factor out
non-dependent parts from each exists term.
Jason: thanks for the "_ \/ _" hint!
-- Jonathan
- [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), Jonathan, 07/22/2014
- Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), Jason Gross, 07/22/2014
- Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), Jonathan, 07/22/2014
- Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), Jason Gross, 07/23/2014
- Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), Jonathan, 07/23/2014
- Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), Arnaud Spiwack, 07/23/2014
- Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), Xavier Leroy, 07/23/2014
