- To: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.)
- Date: Wed, 23 Jul 2014 16:07:11 +0100
Er, I think I meant [refine (_ /\ _)], not [refine (_ : _ /\ _)]. [assert R] says "give me a goal whose type is R", which isn't actually what you want if [R] might be unprovable. I suppose you might be able to do something like
let T := type of R in
let R' := fresh in
refine (let R' : T := _ in _);
[ refine (_ /\ _)
| intro R'; unify R' R ]
Maybe?
Anyway, is this what you're looking for, to find deeply nested evars?
(** Test if a tactic succeeds, but always roll-back the results *)
Tactic Notation "test" tactic3(tac) :=
try (first [ tac | fail 2 tac "does not succeed" ]; fail tac "succeeds"; [](* test for [t] solved all goals *)).
(** [not tac] is equivalent to [fail tac "succeeds"] if [tac] succeeds, and is equivalent to [idtac] if [tac] fails *)
Tactic Notation "not" tactic3(tac) := try ((test tac); fail 1 tac "succeeds").
(** Traverses down nested [_ /\ _] looking for the right-most evar clause
Ltac find_right_most_evar_in_and term :=
match term with
| ?L /\ ?R => let check := $(has_evar R; exact I)$ in find_right_most_evar_in_and R
| ?L /\ ?R => let check := $(not (has_evar R); has_evar L; exact I)$ in find_right_most_evar_in_and L
| _ => let check := $(is_evar term; exact I)$ in term
| _ => fail 1 "No right-most evar clause in" term
end.
(I haven't actually tested this.)
On Wed, Jul 23, 2014 at 3:42 PM, Jonathan <jonikelee AT gmail.com> wrote:
On 07/23/2014 10:29 AM, Jason Gross wrote:That doesn't work for me at all - why not ...=> is_evar R; assert R?
If you have your hands on an evar in Ltac, is there a way to get it as a
goal? For example, could I do something like:
match type of H with
| _ /\ ?R => is_evar R; R: refine (_ : _ /\ _)
end
Also, this doesn't answer my question of how to deal with evars buried deep inside of complex terms.
-- Jonathan
- Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), (continued)
- Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), Jason Gross, 07/22/2014
- Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), Jonathan, 07/22/2014
- Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), Jason Gross, 07/23/2014
- Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), Jonathan, 07/23/2014
- Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), Arnaud Spiwack, 07/23/2014
- Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), Xavier Leroy, 07/23/2014
- [Coq-Club] nice evar tactics (was: Re: Prop smuggling (was: Re: Smart case analysis in Coq.)), Jonathan, 07/23/2014
- Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), Arnaud Spiwack, 07/24/2014
- Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), Jonathan, 07/24/2014
- Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), Jason Gross, 07/24/2014
