- To: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.)
- Date: Wed, 23 Jul 2014 00:18:07 +0100
On Tue, Jul 22, 2014 at 9:43 PM, Jonathan <jonikelee AT gmail.com> wrote:
On 07/22/2014 02:33 PM, Jason Gross wrote:Note that I originally tried normal =, and it worked so long as I used destruct in smuggler instead of case - but the resulting equalities were just as unusable in the result (also, rewriting the result failed - as with the final rewrite or_false_r in logicalize). I decided to use JMeq instead because it seemed to get further, but still hits a wall. Dropping all equality works - but then one loses ability to tie the generated hypothesis back to the original one.
I haven't really looked at the code carefully, but, a few comments:
- You can use [constructor] rather than [tauto] in [smuggler] to prove your
[JMeq] (however, note that using JMeq sets you up for contradicting
univalence; the only way to get from JMeq to eq is by assuming that the
universe is a set)
What you want to do, I suspect, is detect which arguments to the type get unified by destruct, explicitly provide equalities in those cases (and only those cases, unless you want to assume UIP), and then explicitly cast across all of those equality proofs to turn your value into the type you want it to be. It's a pain and a hassle, especially to do in general, but equality is a tricky business, and you need to carefully manage your proofs to get away with not needing axioms.
If you mean on the output hypothesis of logicalize, cbv beta does nothing. I have been composing some rewrite rules to get rid of the extraneous stuff - although it might be easier if doexistify was smarter about not over-complicating things, and if smuggler tried to eliminate false branches (either by using inversion, or proving a contradiction itself).
- You might want to use [cbv beta in <hypothesis>] to get rid of all the
function applications.
Trunk might be smarter about running beta. In 8.4, the output of logicalize is
(exists v_0 : Prop,
(fun P : Prop =>
exists v_1 : nat,
(fun n : nat =>
exists v_2 : nat -> Prop,
(fun P0 : nat -> Prop =>
exists v_3 : P0 n,
(fun p : P0 n =>
exists v_4 : P,
(fun q : P =>
exists v_5 : bool,
(fun b : bool =>
exists v_6 : nat,
(fun n0 : nat =>
exists v_7 : P0 n0,
(fun p0 : P0 n0 =>
exists v_8 : n = n0,
(fun e : n = n0 =>
JMeq.JMeq x (X1 P n P0 p q b n0 p0 e)) v_8)
v_7) v_6) v_5) v_4) v_3) v_2) v_1) v_0) \/
(exists v_0 : Prop,
(fun P : Prop =>
exists v_1 : bool,
(fun b : bool =>
exists v_2 : bool -> Prop,
(fun P0 : bool -> Prop =>
exists v_3 : P0 b,
(fun r : P0 b =>
exists v_4 : P,
(fun q : P => JMeq.JMeq x (X2 P b P0 r q)) v_4) v_3)
v_2) v_1) v_0) \/
JMeq.JMeq x X3 \/ (exists v_0 : 1 = 2, JMeq.JMeq x (X4 v_0))
Sorry, I'm using a trunk version. I am addicted to its evar backtracking abilities.
- Your first example fails for me in Coq 8.4pl4 with
Toplevel input, characters 0-12:
In nested Ltac calls to "logicalize" and
"instantiate ( 1 := False ) in (Value of P)" (expanded to
"instantiate ( 1 := False ) in (Value of P_)"), last call failed.
Error: Instantiate called on already-defined evar
I believe [instantiate] is unofficially deprecated in trunk. I generally prefer to handle evars manually, rather than by number, but, *shrugs*
I haven't been able to get it to work. For instance, after Focus 3, inversion y0 produces
- To answer your comment about the failure, if you [Set Printing Implicit],
you'll notice that the type of [y] is [Y (S m) (S n)], but the type of [Y3
(S m)] is [Y (S m) 3]. So you first need to extract the fact that [n = 3]
(you should be able to do this without any axioms), use that to get rid of
[n], and then you can use [JMeq_eq] in the hypothesis.
-Jason
H1 : Y (S m) (S n) = Y (S m) 3, but using that to rewrite y dies with:
Toplevel input, characters 7-23:
Error: Cannot instantiate metavariable P of type "Type -> Prop" with
abstraction "fun T : Type => T" of incompatible type
"Type -> Type".
No idea why you get that particular error message (in 8.4, you get something like "Error: Abstracting over the term "Y (S m) (S n)" leads to a term "fun P : Prop => JMeq.JMeq y (Y3 (S m))" which is ill-typed."), but, in any case. your desired rewrite is impossible without an additional axiom as long as you have [Q (S m) (S n) y] lying around. If you assume univalence, you get that [Y 4 4 = Y 4 3], because both have one constructor. This means that, without an axiom contradicting univalence, you can't get [S n = 3] from [Y (S m) (S n) = Y (S m) 3]. If you drop your [Q (S m) (S n) y] hypothesis, then you can do [generalize dependent (Y (S m) (S n)); intros; subst] and now you can do your rewrite.
On Tue, Jul 22, 2014 at 3:04 PM, Jonathan <jonikelee AT gmail.com> wrote:
Attached is a first attempt at a general-purpose "Prop smuggling" tactic:
logicalize. The point is to take a Prop hypothesis and "invert" it even
when the current context is not Prop - producing a disjunction of exists
terms, one for each constructor.
However, the JMeq's don't work in the result, as demonstrated in the
second test. Can anyone figure out what's going wrong? If not, they can
just be omitted.
Also needed is a way to simplify out false cases and factor out
non-dependent parts from each exists term.
Jason: thanks for the "_ \/ _" hint!
-- Jonathan
- [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), Jonathan, 07/22/2014
- Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), Jason Gross, 07/22/2014
- Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), Jonathan, 07/22/2014
- Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), Jason Gross, 07/23/2014
- Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), Jonathan, 07/23/2014
- Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), Arnaud Spiwack, 07/23/2014
- Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), Xavier Leroy, 07/23/2014
- [Coq-Club] nice evar tactics (was: Re: Prop smuggling (was: Re: Smart case analysis in Coq.)), Jonathan, 07/23/2014
