- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.)
- Date: Wed, 23 Jul 2014 14:21:38 +0200
On 23/07/2014 10:44, Arnaud Spiwack wrote:
> Coq has a lot of backstory and stuff. So the treatment of existential
> variables is not superbly uniform. In trunk, the [refine] tactic
> introduces existential variable as goals. It is the preferred way to
> manipulate existential variable explicitly.
I don't enjoy counting evar occurrences from the right any more than
you, but there is one situation where I often have to use instantiate:
after a "erewrite", to fix up some of the evars this tactic introduced.
AFAIK, there is no "erewrite ... with (var := value)" like there is
for "eapply".
> But hopefully, we can get rid of [instantiate] eventually: it's not
> a very elegant solution.
Make sure you have decent alternatives for all current uses of
"instantiate" before your sense of elegance takes over. Thanks in
advance.
- Xavier Leroy
- [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), Jonathan, 07/22/2014
- Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), Jason Gross, 07/22/2014
- Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), Jonathan, 07/22/2014
- Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), Jason Gross, 07/23/2014
- Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), Jonathan, 07/23/2014
- Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), Arnaud Spiwack, 07/23/2014
- Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), Xavier Leroy, 07/23/2014
- [Coq-Club] nice evar tactics (was: Re: Prop smuggling (was: Re: Smart case analysis in Coq.)), Jonathan, 07/23/2014
- Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), Arnaud Spiwack, 07/24/2014
- Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), Jonathan, 07/24/2014
