- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Plugins with Vernac that supports backtracking & extra data
- Date: Mon, 25 Aug 2014 15:36:13 -0400
Thanks. This is really helpful.
On Sun, Aug 24, 2014 at 4:45 AM, Enrico Tassi <enrico.tassi AT inria.fr> wrote:
On Sat, Aug 23, 2014 at 11:49:59PM -0400, Gregory Malecha wrote:Look at library/summary.mli (for 1) and library/libobject.mli (for 2).
> 1) Hooks into the backtracking machinery of Coq's toplevel? In particular,
> I have an imperative map that I want to be able to remove elements from
> when the "add new element" command is undone.
> 2) I would also like to store information (that imperative map) in .vo
> files so that it will be restored when I Require a file that builds one of
> these maps. Is there any convenient way to do this?
A comprehensive example is plugins/setoid_ring/newring.ml4 (look for
from_carrier). I doubt you need the full complexity of subst_th.
Best,
Enrico Tassi
gregory malecha
- [Coq-Club] Plugins with Vernac that supports backtracking & extra data, Gregory Malecha, 08/24/2014
- Re: [Coq-Club] Plugins with Vernac that supports backtracking & extra data, Enrico Tassi, 08/24/2014
- Re: [Coq-Club] Plugins with Vernac that supports backtracking & extra data, Gregory Malecha, 08/25/2014
