coq-club - Re: [Coq-Club] Coq's cofixpoint productivity checker -- a parametricity-based approach
  • To: coq-club AT inria.fr, Jason Gross <jasongross9 AT gmail.com>
  • Cc: Jasmin Blanchette <blanchette AT in.tum.de>, Dmitriy Traytel <traytel AT in.tum.de>
  • Subject: Re: [Coq-Club] Coq's cofixpoint productivity checker -- a parametricity-based approach
  • Date: Mon, 25 Aug 2014 19:23:28 +0200
Tracking guardedness in the type system does the job, this is your code in Agda:
{-# OPTIONS --copatterns #-}
open import Data.List
open import Data.Product renaming (proj₁ to fst; proj₂ to snd)
open import Size
record Stream (i : Size) (A : Set) : Set where
coinductive
constructor _∷_
field
head : A
tail : ∀{j : Size< i} → Stream j A
open Stream
prepend : ∀{i A} → List A → Stream i A → Stream i A
prepend [] s = s
prepend (a ∷ as) s = a ∷ prepend as s
flatten : ∀{i A} → Stream i (A × List A) → Stream i A
head (flatten s) = fst (head s)
tail (flatten s) = prepend (snd (head s)) (flatten (tail s))
On 22.08.2014 12:01, Andrei Popescu wrote:
Greetings,
I would like to advocate an approach for obtaining flexible corecursive
principles in a light-weight fashion, without the need to modify the
definitions or add any type annotations. The only overhead is the
requirement to track parametricity.
In short, many operations can be recorded as well-behaved (i.e., OK to
appear in the corecursive call context along with constructors), after
checking that their defining equation (i.e., technically, the structural
operation of its defining coalgebra) has a parametric component. For
example, if defined with CoFixpoint instead of Fixpoint, Jason's
"stream_prepend_list" is well-behaved whereas the stream "tail" is not.
The following paper describes the approach starting with simple
examples, also covering mixed recursion-corecursion:
http://www4.in.tum.de/~popescua/pdf/fouco.pdf
My colleagues and I have implemented a prototype of this approach in
Isabelle -- it is immediately applicable to the simple-type fragment of
Coq. While not being an expert in Coq or dependent types, I believe that
it can be extended to cope with dependent types as well, thanks to
Bernardy's work on PTS parametricity and its follow-up implementation in
Coq (http://www.lix.polytechnique.fr/%7Ekeller/Recherche/coqparam.html).
At its core, this notion of safely enriching corecursion incrementally
is not new, and has been advocated by category theorists for years.
Unfortunately, it has not made it (yet) into mainstream theorem proving.
All the best,
Andrei
On Wednesday, August 20, 2014 6:32 PM, Jason Gross
wrote:
Hi,
Why does Coq not notice that the following definition is manifestly
productive?
Require Import Coq.Lists.Streams.
Fixpoint stream_prepend_list {T} (ls : list T) (rest : Stream T) :
Stream T :=
match ls with
| nil => rest
| cons x xs => Cons x (stream_prepend_list xs rest)
end.
CoFixpoint flatten_stream {T} (s : Stream (T * list T)) : Stream T :=
match s with
| Cons x xs => Cons (fst x) (stream_prepend_list (snd x)
(flatten_stream xs))
end.
(* Error:
Recursive definition of flatten_stream is ill-formed.
In environment
flatten_stream : forall T : Type, Stream (T * list T) -> Stream T
T : Type
x : T * list T
xs : Stream (T * list T)
Sub-expression "stream_prepend_list (snd x) (flatten_stream T xs)" not in
guarded form (should be a constructor, an abstraction, a match, a cofix or a
recursive call).
Recursive definition is:
"fun (T : Type) (s : Stream (T * list T)) =>
match s with
| Cons x xs =>
Cons (fst x) (stream_prepend_list (snd x) (flatten_stream T xs))
end". *)
It seems that Coq doesn't want me to put anything between the recursive
call and the constructor, but it's syntactically obvious that my
definition is productive...
-Jason
Andreas Abel <>< Du bist der geliebte Mensch.
Department of Computer Science and Engineering
Chalmers and Gothenburg University, Sweden
andreas.abel AT gu.se
http://www2.tcs.ifi.lmu.de/~abel/
open import Size
coinductive
constructor _∷_
field
head : A
open Stream
prepend [] s = s
