Re: [Coq-Club] Coq's cofixpoint productivity checker -- a parametricity-based approach
- To: "coq-club AT inria.fr" <coq-club AT inria.fr>, Jason Gross <jasongross9 AT gmail.com>
- Cc: Jasmin Blanchette <blanchette AT in.tum.de>, Dmitriy Traytel <traytel AT in.tum.de>
- Subject: Re: [Coq-Club] Coq's cofixpoint productivity checker -- a parametricity-based approach
- Date: Mon, 25 Aug 2014 14:10:50 -0700
Hi Andreas,
Of course, sized types are an elegant and powerful solution. However, the
parametricity-based alternative has the advantage that it needs no size
annotations (and indeed, no annotations at all). On the downside, it is less
expressive and does require discharging a parametricity goal, which can
typically be done automatically using a standard parametricity prover though.
Here is the Isabelle version of "flatten", using a sugar notation that is not
yet available, but will hopefully be there in the next release:
codatatype 'a stream = Cons (head: 'a) (tail: "'a stream") (infixr "##" 65)
corec (well_behaved) prepend : 'a list => 'a stream => 'a stream
where
prepend as s =
(case as of [] => s
|a # as => a ## prepend as s
well_behavedness by parametricity_prover
(* at this point, prepend has been registered as well-behaved, hence it can
participate in call contexts
for future corecursively defined functions *)
corec flatten : ('a * 'a list) stream => 'a stream
where
flatten s = fst (head s) ## prepend (snd (head s)) (flatten (tail s))
All the best,
Andrei
On Monday, August 25, 2014 8:23 PM, Andreas Abel
<andreas.abel AT ifi.lmu.de>
wrote:
Tracking guardedness in the type system does the job, this is your code
in Agda:
{-# OPTIONS --copatterns #-}
open import Data.List
open import Data.Product renaming (proj₁ to fst; proj₂ to snd)
open import Size
record Stream (i : Size) (A : Set) : Set where
coinductive
constructor _∷_
field
head : A
tail : ∀{j : Size< i} → Stream j A
open Stream
prepend : ∀{i A} → List A → Stream i A → Stream i A
prepend [] s = s
prepend (a ∷ as) s = a ∷ prepend as s
flatten : ∀{i
A} → Stream i (A × List A) → Stream i A
head (flatten s) = fst (head s)
tail (flatten s) = prepend (snd (head s)) (flatten (tail s))
On 22.08.2014 12:01, Andrei Popescu wrote:
> Greetings,
> I would like to advocate an approach for obtaining flexible corecursive
> principles in a light-weight fashion, without the need to modify the
> definitions or add any type annotations. The only overhead is the
> requirement to track parametricity.
> In short, many operations can be recorded as well-behaved (i.e., OK to
> appear in the corecursive call context along with constructors), after
> checking that their defining equation (i.e.,
technically, the structural
> operation of its defining coalgebra) has a parametric component. For
> example, if defined with CoFixpoint instead of Fixpoint, Jason's
> "stream_prepend_list" is well-behaved whereas the stream "tail" is not.
> The following paper describes the approach starting with simple
> examples, also covering mixed recursion-corecursion:
> http://www4.in.tum.de/~popescua/pdf/fouco.pdf
> My colleagues and I have implemented a prototype of this approach in
> Isabelle -- it is immediately applicable to the simple-type fragment of
> Coq. While not being an expert in Coq or dependent types, I believe that
> it can be extended to cope with dependent types as well, thanks to
> Bernardy's work on PTSparametricity and its follow-up implementation in
> Coq (http://www.lix.polytechnique.fr/%7Ekeller/Recherche/coqparam.html).
> At its core, this notion of safely enriching corecursion incrementally
> is not new, and has been advocated by category theorists for years.
> Unfortunately, it has not made it (yet) into mainstream theorem proving.
> All the best,
> Andrei
> On Wednesday, August 20, 2014 6:32 PM, Jason Gross
> wrote:
> Hi,
> Why does Coq not notice that the following definition is manifestly
> productive?
> Require Import Coq.Lists.Streams.
> Fixpoint stream_prepend_list {T} (ls : list T) (rest : Stream T) :
> Stream T :=
> match ls with
> | nil => rest
> | cons x xs => Cons x (stream_prepend_list xs rest)
> end.
> CoFixpoint flatten_stream {T} (s : Stream (T * list T)) : Stream T :=
> match s with
> | Cons x xs => Cons (fst x) (stream_prepend_list (snd x)
> (flatten_stream xs))
> end.
> (* Error:
> Recursive definition of flatten_stream is ill-formed.
> In environment
> flatten_stream : forall T : Type, Stream (T * list T) -> Stream T
> T : Type
> x : T * list T
> xs : Stream (T * list T)
> Sub-expression "stream_prepend_list (snd x) (flatten_stream T xs)" not in
> guarded form (should be a constructor, an abstraction, a match, a cofix or a
> recursive call).
> Recursive definition is:
> "fun (T : Type) (s : Stream (T * list T)) =>
> match s with
> | Cons x xs =>
> Cons (fst x) (stream_prepend_list (snd x) (flatten_stream T xs))
> end". *)
> It seems that Coq doesn't want me to put anything between the recursive
> call and the constructor, but it's syntactically obvious that my
> definition is productive...
> -Jason
Andreas Abel <>< Du bistdergeliebte Mensch.
Department of Computer Science and Engineering
Chalmers and Gothenburg University, Sweden
andreas.abel AT gu.se
http://www2.tcs.ifi.lmu.de/~abel/
- [Coq-Club] Coq's cofixpoint productivity checker, Jason Gross, 08/20/2014
- Re: [Coq-Club] Coq's cofixpoint productivity checker, Adam Chlipala, 08/20/2014
- Re: [Coq-Club] Coq's cofixpoint productivity checker, Maxime Dénès, 08/20/2014
- Re: [Coq-Club] Coq's cofixpoint productivity checker, Daniel Schepler, 08/20/2014
- Re: [Coq-Club] Coq's cofixpoint productivity checker, Jonathan, 08/22/2014
- Re: [Coq-Club] Coq's cofixpoint productivity checker -- a parametricity-based approach, Andrei Popescu, 08/22/2014
- Re: [Coq-Club] Coq's cofixpoint productivity checker -- a parametricity-based approach, Andreas Abel, 08/25/2014
- Re: [Coq-Club] Coq's cofixpoint productivity checker -- a parametricity-based approach, Andrei Popescu, 08/25/2014
