- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] an evar with a split personality
- Date: Thu, 04 Sep 2014 11:29:09 -0400
On 09/04/2014 09:20 AM, Arnaud Spiwack wrote:
The reason why is looks weird is because you are misunderstanding what
existential var instances are: they are not the context of the existential
variable, but an explicit substitution which must be applied when the
existential variable takes a value.
In your case, [rewrite aeqb] makes it so that every [a] in the [?9] of the
conclusion must be replaced by [b]. Which is what happens. It may be
confusing because both [a] and [b] are variable, but they need not be:
Goal forall a b:nat, a=2*b+a -> exists c:nat, c = c.
intros a b aeqb.
eexists. (*make an evar*)
match goal with |- ?V = ?V => remember V as e eqn:Q end. (*clone the evar*)
rewrite Q at 2. (*make the consequent and Q look really similar*)
rewrite aeqb. (* e = ?9 (* [2 * b + a, b, aeqb] *) *)
instantiate (1:=a). (* e=2*b+a *)
That is very illuminating! I completely misunderstood those lists. But, how does one know, for each substitution in an evar instance list, what is being substituted for? Would it be more helpful if each such substitution was shown as a pair?
Note that the order of hypotheses in the focused goal can't be used to determine what is being substituted for, because of cases like:
intros a b aeqb.
set (d:=0).
move d at top.
where the order of hypotheses is now d, a, b, aeqb but the evar instances are [a, b, aeqb].
OH - that's something that evar dependent subgoals provide! Now this is making more sense:
intros a b aeqb.
refine (ex_intro _ _ _); shelve_unifiable.
Unshelve.
(*watch the context lists while doing:*)
2:set (d:=0).
2:move d at top.
So, an evar instance list, as displayed by Set Printing Existential Instances, is an instance-of-that-evar-specific list of substitutions applied to the similarly-ordered hypotheses in the evar's matching subgoal. Modifying the order of hypotheses in the evar's matching subgoal similarly modifies the order in all of its instance lists. But, each substitution can be modified independently (using rewrite). When the evar is instantiated, the substitutions occur independently at each instance location. The context of the evar is the evar's dependent subgoal - implying that when the evar is instantiated with a term, that term is interpreted within the evar's subgoal, and not within the subgoal where the instantiation took place (the substitutions are interpreted there).
Each evar acts like a function. The evar's dependent subgoal is that function's signature (hypotheses are formal parameters, consequent is result type). The term (eventually) used to instantiate the evar becomes that function's "body". The instance lists are the actual parameter lists at each "call site". Instantiating the evar both provides the body term for the function and causes the function applications to be reduced at all call sites (instances).
Is that correct?
If so, that wasn't complicated, but it was mysterious.
What else besides rewrite can be used to directly alter a substitution? I determined that setoid_rewrite doesn't work. I don't know how to target a substitution with a tactic "at" occurrence.
One can revert all hypotheses in the evar dependent subgoal, which induces skolemization of all of the instances, which then allows normal tactic targeting of those instance lists substitutions, because it makes them into visible actual parameter terms. One can later do "intros" in the evar's dependent subgoal, and undo the skolemization. But the fact that "rewrite aeqb" somehow managed direct access to the instance list seems to suggest that one might avoid skolemization in other ways as well?
-- Jonathan
- [Coq-Club] an evar with a split personality, Jonathan, 09/04/2014
- Re: [Coq-Club] an evar with a split personality, Arnaud Spiwack, 09/04/2014
- Re: [Coq-Club] an evar with a split personality, Jonathan, 09/04/2014
- Re: [Coq-Club] an evar with a split personality, Arnaud Spiwack, 09/12/2014
- Re: [Coq-Club] an evar with a split personality, Jonathan, 09/12/2014
- Re: [Coq-Club] an evar with a split personality, Matthieu Sozeau, 09/12/2014
- Re: [Coq-Club] an evar with a split personality, Hugo Herbelin, 09/13/2014
