- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] problem with tactic-generated terms
- Date: Fri, 12 Sep 2014 16:24:02 -0700
On Fri, Sep 12, 2014 at 3:17 PM, Jonathan
<jonikelee AT gmail.com>
wrote:
> On 09/12/2014 06:04 PM, Jonathan wrote:
> Maybe there is a problem here? I will try to create a contradiction in this
> case, using a Prop that is identical in structure to Erasable, but just not
> itself Erasable - that actually does look possible...
> Inductive Erasable(A : Type) : Prop :=
> erasable: A -> Erasable A.
> Arguments erasable [A] _.
> Axiom Erasable_inj : forall {A : Type}{a b : A}, erasable a=erasable b ->
> a=b.
> Inductive Foo(A : Type) : Prop :=
> foo: A -> Foo A.
> Arguments foo [A] _.
> Set Injection On Proofs. (*fails with or without this*)
> Goal forall i j:nat, foo i=foo j ->erasable i=erasable j.
> intros i j H.
> Fail injection H.
> I can't find a proof for that - can anyone else?
Goal forall {A:Type} (x y:A), foo x = foo y ->
erasable x = erasable y.
Proof.
set (foo_impl_erasable := fun (A:Type) (H:Foo A) =>
match H return (Erasable A) with
| foo a => erasable a
end).
intros.
apply f_equal with (f := foo_impl_erasable A) in H.
simpl in H.
assumption.
Qed.
Daniel Schepler
- Re: [Coq-Club] problem with tactic-generated terms, (continued)
- Re: [Coq-Club] problem with tactic-generated terms, Robert Dockins, 09/13/2014
- Re: [Coq-Club] problem with tactic-generated terms, Jonathan, 09/13/2014
- Re: [Coq-Club] problem with tactic-generated terms, Matthieu Sozeau, 09/13/2014
- Re: [Coq-Club] problem with tactic-generated terms, Daniel Schepler, 09/13/2014
- Re: [Coq-Club] problem with tactic-generated terms, Hugo Herbelin, 09/13/2014
- Re: [Coq-Club] problem with tactic-generated terms, Jonathan, 09/14/2014
- Re: [Coq-Club] problem with tactic-generated terms, Hugo Herbelin, 09/15/2014
- Re: [Coq-Club] problem with tactic-generated terms, Jonathan, 09/15/2014
