- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] problem with tactic-generated terms
- Date: Fri, 12 Sep 2014 15:09:21 -0700
On Fri, Sep 12, 2014 at 2:53 PM, Jonathan
<jonikelee AT gmail.com>
wrote:
> Here's is all that I do, really:
> Inductive Erasable(A : Type) : Prop :=
> erasable: A -> Erasable A.
> Arguments erasable [A] _.
> Axiom Erasable_inj : forall {A : Type}{a b : A}, erasable a=erasable b ->
> a=b.
> I then use "Erasable nat" (##nat via notation) instead of nat, and "erasable
> 42" (#42 via notation) instead of 42.
> I am not sure I understand the difference you are suggesting. For instance,
> are you saying that if I want an erasable constant replacement for 42, I
> instead use a function from a singleton type based on 42 to Prop? And then
> achieve injectivity using some variety of extensionality? Hmmm.....
Here's a simple example of what I was thinking of (though without any
of the hard work which would go into defining something like
vector_map2):
Inductive return_O : nat -> Prop :=
| return_O_intro : return_O O.
Inductive liftM_S (n : nat -> Prop) : nat -> Prop :=
| liftM_S_intro : forall m:nat, n m -> (liftM_S n) (S m).
Inductive vector (A:Type) : (nat -> Prop) -> Type :=
| vector_nil : vector A return_O
| vector_cons : A -> forall {n : nat -> Prop}, vector A n ->
vector A (liftM_S n).
And here are the general monad operations which are respectful of
being singletons, respectful of extensional equality, etc.:
Inductive singleton_return {A:Type} (x:A) : A -> Prop :=
| singleton_return_intro : singleton_return x x.
Inductive singleton_bind {A:Type} (x:A->Prop)
{B:Type} (f:A->(B->Prop)) : B -> Prop :=
| singleton_bind_intro : forall (x0:A) (y:B), x x0 -> f x0 y ->
singleton_bind x f y.
Inductive singleton_algebra_Prop (P : Prop -> Prop) : Prop :=
| singleton_algebra_Prop_intro : forall Q:Prop, P Q -> Q ->
singleton_algebra_Prop P.
Daniel Schepler
- Re: [Coq-Club] problem with tactic-generated terms, (continued)
- Re: [Coq-Club] problem with tactic-generated terms, Matthieu Sozeau, 09/13/2014
- Re: [Coq-Club] problem with tactic-generated terms, Daniel Schepler, 09/13/2014
- Re: [Coq-Club] problem with tactic-generated terms, Hugo Herbelin, 09/13/2014
- Re: [Coq-Club] problem with tactic-generated terms, Jonathan, 09/14/2014
- Re: [Coq-Club] problem with tactic-generated terms, Hugo Herbelin, 09/15/2014
- Re: [Coq-Club] problem with tactic-generated terms, Jonathan, 09/15/2014
- Re: [Coq-Club] problem with tactic-generated terms, Jonathan, 09/13/2014
