coq-club - Re: [Coq-Club] problem with tactic-generated terms
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] problem with tactic-generated terms
  • Date: Mon, 15 Sep 2014 12:11:15 -0400
On 09/15/2014 10:32 AM, Hugo Herbelin wrote:
You would need -impredicative-set option to show that the
interpretation of Prop as the impredicative variant of Set satisfies
your axiom.
Inductive Erasable(S : Set) : Set := erasable: S -> Erasable S.
I note that here Erasable is Set -> Set, not Set -> Prop.
Arguments erasable [S] _.
Theorem Erasable_inj : forall {S : Set}{a b : S}, erasable a=erasable b ->
a=b.
Proof.
intros * H.
set (f := fun (x:Erasable S) => let 'erasable y := x in y).
apply f_equal with (f:=f) in H.
assumption.
Qed.
But that's provable with or without -impredicative-set. (a shorter proof is just: intros * H. injection H. trivial)
But you don't need -impredicative-set to technically postulate your
axiom (having option -impredicative-set on does not ensure in itself
that the interpretation of Prop as the impredicative variant of Set is
sound - an analysis of the CIC rules is necessary -, nor does it
prevent introducing other axioms that would contradict this
interpretation of Prop).
Hugo
I guess in this case, the devil we don't know is better than the devil we do know. I will incorporate a summary of this discussion and its caveats into my github project.
A side note: Making sure that other axioms aren't introduced that cause a problem is not so easy. For example, Program makes use of proof_irrelevance. I guess I should always do Print Assumptions.
A suggestion: how about adding something like a "Restrict Assumptions" command that would take a list of axioms and raise an error if the actual assumptions used is not a subset of those mentioned in the list?
-- Jonathan
