- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] problem with tactic-generated terms
- Date: Sat, 13 Sep 2014 09:19:58 +0200
I stand corrected, thanks!
Le samedi 13 septembre 2014, Jonathan <jonikelee AT gmail.com> a écrit :
On 09/12/2014 07:59 PM, Robert Dockins wrote:
You can get this from the Hurkens paradox; see below.
Cheers,
Rob
Require Hurkens.
Inductive Erasable(A : Type) : Prop := erasable: A -> Erasable A.
Arguments erasable [A] _.
Axiom Erasable_inj : forall {A : Type}{a b : A}, erasable a=erasable b -> a=b.
Definition er_out (X:Erasable Prop) : Prop
:= exists P, X = @erasable Prop P /\ P.
Theorem inconsistent : False.
Proof.
apply (Hurkens.paradox (Erasable Prop) (@erasable Prop) er_out).
intros.
destruct H as [P [H1 H2]].
apply Erasable_inj in H1.
subst A. trivial.
red; intros.
exists A; split; auto.
Qed.
Check inconsistent.
Print Assumptions inconsistent.
I needed to add Import Hurkens.NoRetractFromSmallPropositionToProp. and use "paradox" unqualified, for some reason - but otherwise it does work (I'm using a trunk version). Are things just as bad if I limit Erasable to be over Set instead of Type? That would be somewhat limiting, but maybe still sufficiently useful. Or, if there was a way to limit it to non-universe instances of Type?
Still - the proof (in Daniel Shepler's response) that it is incompatible with specific proof irrelevance is also upsetting - and that would remain even if limited to Set. Although I haven't yet required any variety of proof irrelevance.
Well, either I have to hope reality is sufficiently paraconsistent, or investigate an alternative erasability mechanism. Maybe the one Daniel Shepler is suggesting is suitable.
Or switch to Idris.
-- Jonathan
- Re: [Coq-Club] problem with tactic-generated terms, (continued)
- Re: [Coq-Club] problem with tactic-generated terms, Ömer Sinan Ağacan, 09/12/2014
- Re: [Coq-Club] problem with tactic-generated terms, Jonathan, 09/12/2014
- Re: [Coq-Club] problem with tactic-generated terms, Daniel Schepler, 09/12/2014
- Re: [Coq-Club] problem with tactic-generated terms, Greg Morrisett, 09/12/2014
- Re: [Coq-Club] problem with tactic-generated terms, Jonathan, 09/13/2014
- Re: [Coq-Club] problem with tactic-generated terms, Adam Chlipala, 09/13/2014
- Re: [Coq-Club] problem with tactic-generated terms, Matthieu Sozeau, 09/13/2014
- Re: [Coq-Club] problem with tactic-generated terms, Robert Dockins, 09/13/2014
- Re: [Coq-Club] problem with tactic-generated terms, Daniel Schepler, 09/13/2014
- Re: [Coq-Club] problem with tactic-generated terms, Hugo Herbelin, 09/13/2014
- Re: [Coq-Club] problem with tactic-generated terms, Jonathan, 09/14/2014
- Re: [Coq-Club] problem with tactic-generated terms, Hugo Herbelin, 09/15/2014
- Re: [Coq-Club] problem with tactic-generated terms, Jonathan, 09/15/2014
