- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Eliminate duplicate subgoals?
- Date: Fri, 14 Nov 2014 15:51:22 -0500
On 11/14/2014 02:14 PM, Colm Bhandal wrote:
Hi,
I am wondering if anybody had any idea how to use tactics in Coq to
eliminate identical subgoals? More preciselsy, let's say there are two
subgoals:
[H1, H2, H3, ... |- SG] and [H1, H2, H3, ... |- SG] in the context such
that all the hypotheses and the goals are the same in each case.
It would be nice if there was a tactic "prune" or something to get rid of
the duplicate subgoal. Anybody got any ideas how to write a tactic like
this or does one already exist maybe?
Thanks,
Colm
Unforunately, I don't think there is any way to do such pruning after the subgoals exist. If you see that this is about to happen, as in a case like:
[H1, H2, H3 |- SG /\ SG]
you can, instead of splitting the goal, rewrite the conclusion so that it is just a single SG. Of course, this is a trivial case. It can't handle the case when the subgoals start out being different and then become identical later.
In other cases, if you can solve one of those subgoals in a single (perhaps aggregate) tactic, then you can use abstract with a name to solve the first, then just apply the resulting named lemma to solve the second:
Require Import Omega.
Goal 5 + 3 > 6 /\ 5 + 3 > 6.
split.
abstract omega (*or some other complicated tactic*) using mylemma.
apply mylemma.
Show Proof. (* (conj mylemma mylemma) *)
Qed.
I recall that having an interactive version of the "abstract" tactic was once discussed - which would package up any proved subgoal as a separate named lemma, even one that is interactively proved.
-- Jonathan
- [Coq-Club] Eliminate duplicate subgoals?, Colm Bhandal, 11/14/2014
- Re: [Coq-Club] Eliminate duplicate subgoals?, Jonathan, 11/14/2014
- Re: [Coq-Club] Eliminate duplicate subgoals?, Jason Gross, 11/14/2014
- Re: [Coq-Club] Eliminate duplicate subgoals?, Jonathan, 11/15/2014
- Re: [Coq-Club] Eliminate duplicate subgoals?, Randy Pollack, 11/15/2014
- Re: [Coq-Club] Eliminate duplicate subgoals?, Enrico Tassi, 11/15/2014
- Re: [Coq-Club] Eliminate duplicate subgoals?, Pierre-Marie Pédrot, 11/15/2014
- Re: [Coq-Club] Eliminate duplicate subgoals?, Colm Bhandal, 11/15/2014
