- From: Pierre-Marie Pédrot <pierre-marie.pedrot AT inria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Eliminate duplicate subgoals?
- Date: Sat, 15 Nov 2014 13:47:54 +0100
On 15/11/2014 10:06, Enrico Tassi wrote:
> In trunk goals can be named. I did not test that, but I guess you can:
> refine ?[theothergoal]. (* or maybe even exact *)
> to merge the ongoing goal with another one named "theothergoal".
Yep, I even proposed a generalized version of this some time ago, under
the form of a [wlog] tactic. If you have some goals
[ g1 : Γ1 ⊢ A1 ; ... ; gn : Γn ⊢ An ]
then [wlog gi] results in the state
[ g1 : (forall Γi : Ai), Γ1 ⊢ A1 ; ... ; gn : Γn ⊢ An ]
with some occur check to prevent loops.
This would allow to do a lot of proof by symmetry in a very simple way.
This is very easy to implement, but at the penultimate Coq WG, nobody
seemed really interested so I just forgot about it. But if people here
on Coq-club are interested, I can write it out.
PMP
signature.asc
Description: OpenPGP digital signature
- [Coq-Club] Eliminate duplicate subgoals?, Colm Bhandal, 11/14/2014
- Re: [Coq-Club] Eliminate duplicate subgoals?, Jonathan, 11/14/2014
- Re: [Coq-Club] Eliminate duplicate subgoals?, Jason Gross, 11/14/2014
- Re: [Coq-Club] Eliminate duplicate subgoals?, Jonathan, 11/15/2014
- Re: [Coq-Club] Eliminate duplicate subgoals?, Randy Pollack, 11/15/2014
- Re: [Coq-Club] Eliminate duplicate subgoals?, Enrico Tassi, 11/15/2014
- Re: [Coq-Club] Eliminate duplicate subgoals?, Pierre-Marie Pédrot, 11/15/2014
- Re: [Coq-Club] Eliminate duplicate subgoals?, Colm Bhandal, 11/15/2014
- Re: [Coq-Club] Eliminate duplicate subgoals?, Daniel Schepler, 11/15/2014
- Re: [Coq-Club] Eliminate duplicate subgoals?, Cedric Auger, 11/15/2014
