- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Eliminate duplicate subgoals?
- Date: Fri, 14 Nov 2014 20:54:42 -0500
On 11/14/2014 04:56 PM, Jonathan wrote:
On 11/14/2014 04:34 PM, Jason Gross wrote:
It should be possible to write a pair of tactics, [prepare_pruning] and
[prune], such that the first one is to be run at the very beginning of the
proof, and sets up an evar or dependent subgoal for the latter to use, and
the latter partially instantiates the evar to solve two goals but create a
single new one.
-Jason
Yes - but that requires you to know far enough in advance you that will need it, and how often you will need it (as a separate evar is needed for each case).
Or, not. As I recall, Jason, you pointed out this "_ /\ _" trick a while ago:
Variables P Q R : Prop.
Axiom okp : P.
Axiom okq : Q.
Axiom okr : R.
Ltac prepare_pruning v := refine (let v := _ in _); shelve_unifiable.
Ltac prune v := try tauto; instantiate (1:=_/\_) in (Type of v); decompose [and] v; eauto.
Ltac split_pruned := repeat split; [exact I|..].
Goal P /\ Q /\ R /\ Q /\ P /\ Q /\ R /\ R /\ P /\ Q.
prepare_pruning pruner.
repeat split.
all: prune pruner.
Unshelve.
split_pruned.
apply okr.
apply okq.
apply okp.
Qed.
Probably requires some work to make this work for goals complete with their hypotheses (extra points of the order of hypotheses doesn't matter, and if subsuming goals can be combined) - but this is a good starting point. Still requires the annoying "prepare_pruning" initialization, though.
-- Jonathan
- [Coq-Club] Eliminate duplicate subgoals?, Colm Bhandal, 11/14/2014
- Re: [Coq-Club] Eliminate duplicate subgoals?, Jonathan, 11/14/2014
- Re: [Coq-Club] Eliminate duplicate subgoals?, Jason Gross, 11/14/2014
- Re: [Coq-Club] Eliminate duplicate subgoals?, Jonathan, 11/15/2014
- Re: [Coq-Club] Eliminate duplicate subgoals?, Randy Pollack, 11/15/2014
- Re: [Coq-Club] Eliminate duplicate subgoals?, Enrico Tassi, 11/15/2014
- Re: [Coq-Club] Eliminate duplicate subgoals?, Pierre-Marie Pédrot, 11/15/2014
- Re: [Coq-Club] Eliminate duplicate subgoals?, Colm Bhandal, 11/15/2014
- Re: [Coq-Club] Eliminate duplicate subgoals?, Daniel Schepler, 11/15/2014
