coq-club - Re: [Coq-Club] Eliminate duplicate subgoals?
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Eliminate duplicate subgoals?
  • Date: Fri, 14 Nov 2014 16:56:23 -0500
On 11/14/2014 04:34 PM, Jason Gross wrote:
It should be possible to write a pair of tactics, [prepare_pruning] and
[prune], such that the first one is to be run at the very beginning of the
proof, and sets up an evar or dependent subgoal for the latter to use, and
the latter partially instantiates the evar to solve two goals but create a
single new one.
-Jason
Yes - but that requires you to know far enough in advance you that will need it, and how often you will need it (as a separate evar is needed for each case).
Something like:
Require Import Omega.
Goal forall x y z, x=5 -> y=3 -> z=6 -> x + y > z /\ x + y > z.
intros x y z H1 H2 H3.
refine (let pruner:=_ in _);shelve_unifiable.
split.
revert x y z H1 H2 H3.
match goal with |- ?G => instantiate (1:=G) in (Type of pruner) end.
intros.
apply pruner; assumption.
Unshelve.
intros.
omega. (*the one actual proof*)
Qed.
-- Jonathan
On Fri, Nov 14, 2014 at 3:51 PM, Jonathan
<jonikelee AT gmail.com>
wrote:
On 11/14/2014 02:14 PM, Colm Bhandal wrote:
Hi,
I am wondering if anybody had any idea how to use tactics in Coq to
eliminate identical subgoals? More preciselsy, let's say there are two
subgoals:
[H1, H2, H3, ... |- SG] and [H1, H2, H3, ... |- SG] in the context such
that all the hypotheses and the goals are the same in each case.
It would be nice if there was a tactic "prune" or something to get rid of
the duplicate subgoal. Anybody got any ideas how to write a tactic like
this or does one already exist maybe?
Thanks,
Colm
Unforunately, I don't think there is any way to do such pruning after the
subgoals exist. If you see that this is about to happen, as in a case like:
[H1, H2, H3 |- SG /\ SG]
you can, instead of splitting the goal, rewrite the conclusion so that it
is just a single SG. Of course, this is a trivial case. It can't handle
the case when the subgoals start out being different and then become
identical later.
In other cases, if you can solve one of those subgoals in a single
(perhaps aggregate) tactic, then you can use abstract with a name to solve
the first, then just apply the resulting named lemma to solve the second:
Goal 5 + 3 > 6 /\ 5 + 3 > 6.
split.
abstract omega (*or some other complicated tactic*) using mylemma.
apply mylemma.
Show Proof. (* (conj mylemma mylemma) *)
Qed.
I recall that having an interactive version of the "abstract" tactic was
once discussed - which would package up any proved subgoal as a separate
named lemma, even one that is interactively proved.
-- Jonathan
