- To: coq-club AT inria.fr
- Subject: [Coq-Club] setoid rewriting -- naive questions
- Date: Tue, 18 Nov 2014 11:25:01 -0800
I am trying to prove following lemma:
Lemma map2_setoid_comm `{Equiv B} `{Commutative B A}:
forall n (a b: vector A n),
(map2 f a b) = (map2 f b a).
I am using Equiv and Commutative type classes from CoRN. For convenience I am
also using VecUtil from CoLoR which provide several handy definitions for
fixed-size vectors.
Require Import abstract_algebra orders.minmax interfaces.orders.
Require Import MathClasses.theory.rings.
Require Import CoLoR.Util.Vector.VecUtil.
Import VectorNotations.
The equivalence used here (=) is 'equiv'. I was able to instantiate:
Definition vec_equiv `{Equiv A} {n}: relation (vector A n) := Vforall2 (n:=n)
equiv.
Instance vec_Equiv `{Equiv A} {n}: Equiv (vector A n) := vec_equiv.
which permitted me to use reflexivity tactics to prove IH. Now I am trying
to use 'commutativity' but no luck so far:
1 subgoals, subgoal 1 (ID 1405)
B : Type
H : Equiv B
H0 : Equiv B
A : Type
f : A → A → B
H1 : Commutative f
n : nat
a : vector A (S n)
b : vector A (S n)
IHn : ∀ a0 b0 : vector A n, map2 f a0 b0 = map2 f b0 a0
Vcons (f (Vhead a) (Vhead b)) (map2 f (Vtail a) (Vtail b)) = map2 f b a
As the next step I want rewrite LHS cons head by replacing (f (Vhead a)
(Vhead b)) with (f (Vhead b) (Vhead a)) by commutativity. I could not make it
work with any of rewrite tactics.
I will appreciate if somebody would point me in the right direction. Thanks!
Sincerely,
Vadim
- [Coq-Club] setoid rewriting -- naive questions, Vadim Zaliva, 11/18/2014
- Re: [Coq-Club] setoid rewriting -- naive questions, Robbert Krebbers, 11/18/2014
- Re: [Coq-Club] setoid rewriting -- naive questions, Vadim Zaliva, 11/18/2014
- Re: [Coq-Club] setoid rewriting -- naive questions, Daniel Schepler, 11/18/2014
- Re: [Coq-Club] setoid rewriting -- naive questions, Vadim Zaliva, 11/19/2014
- Re: [Coq-Club] setoid rewriting -- naive questions, Daniel Schepler, 11/19/2014
- Re: [Coq-Club] setoid rewriting -- naive questions, Jonathan, 11/19/2014
