- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] setoid rewriting -- naive questions
- Date: Tue, 18 Nov 2014 17:47:26 -0800
On Tue, Nov 18, 2014 at 4:51 PM, Vadim Zaliva <vzaliva AT cmu.edu> wrote:
B : TypeH : Equiv BH0 : Equiv BA : Typef : A → A → BH1 : Commutative fn : nata : vector A (S n)b : vector A (S n)IHn : ∀ a0 b0 : vector A n, map2 f a0 b0 = map2 f b0 a0============================VConsR (map2 f (Vtail a) (Vtail b)) (f (Vhead a) (Vhead b)) = map2 f b aAt this point trying:replace (f (Vhead a) (Vhead b)) with (f (Vhead b) (Vhead a)) by commutativity.Gives:...
You appear to have two instances of Equiv B, which could be confusing things. My guess would be that you have something like `{Equiv B} `{Commutative f} where the second should be `{!Commutative f} instead. Also, I don't see any instances of Setoid B which could be useful in inferring Setoid (Vector.t B (S n)), which in turn would be useful for doing the rewriting.
That said, when I tried it with a similar situation with only one Equiv B, and Setoid B in the context (and a registered instance of forall (A:Type) `{Setoid A} (n:nat), Setoid (Vector.t A n)), it still didn't work for me.
1 subgoals
A : Type
B : Type
f : A -> A -> B
H : Equiv B
H0 : Setoid B
Commutative0 : Commutative f
h : A
n : nat
w : Vector.t A (S n)
h' : A
n0 : nat
t' : Vector.t A n0
v0 : Vector.t A n0
IHv0 : forall y : Vector.t A n0, (=) (map2 f v0 y) (map2 f y v0)
H1 : (=) (f h h') (f h' h)
H2 : forall (A0 : Type) (H2 : Equiv A0) (n1 : nat),
Proper ((=) ==> vector_equiv A0 n1 ==> vector_equiv A0 (S n1))
vcons_reord
H3 : forall (A0 : Type) (H3 : Equiv A0),
Setoid A0 -> forall n1 : nat, Setoid (Vector.t A0 n1)
______________________________________(1/1)
(=) (vcons_reord (f h h') (map2 f v0 t'))
(vcons_reord (f h' h) (map2 f t' v0))
rewrite H1.
Error:
Tactic failure:Unable to satisfy the rewriting constraints.
Unable to satisfy the following constraints:
EVARS:
?394==[A B f H H0 Commutative0 h n w h' n0 t' v0 IHv0 H1
|- ProperProxy ?392 (vcons_reord (f h' h) (map2 f t' v0))]
(internal placeholder)
?393==[A B f H H0 Commutative0 h n w h' n0 t' v0 IHv0 H1
(do_subrelation:=do_subrelation)
|- Proper (?385 ==> ?392 ==> Basics.flip Basics.impl) (=)]
?392==[A B f H H0 Commutative0 h n w h' n0 t' v0 IHv0 H1
|- relation (Vector.t B (S n0))] (internal placeholder)
?388==[A B f H H0 Commutative0 h n w h' n0 t' v0 IHv0 H1
|- ProperProxy ?386 (map2 f v0 t')] (internal placeholder)
?387==[A B f H H0 Commutative0 h n w h' n0 t' v0 IHv0 H1
|- Proper ((=) ==> ?386 ==> ?385) vcons_reord]
?386==[A B f H H0 Commutative0 h n w h' n0 t' v0 IHv0 H1
|- relation (Vector.t B n0)] (internal placeholder)
?385==[A B f H H0 Commutative0 h n w h' n0 t' v0 IHv0 H1
UNIVERSES:
Top.9442 <= Top.7471
Top.9441 <= Top.7470
Top.9438 <= Top.6223
Top.9423 <= Top.7236
Top.9422 <= Coq.Init.Logic.47
Top.9408 <= Top.7236
Top.9407 <= Coq.Init.Logic.47
Top.9002 <= Coq.Vectors.VectorDef.3
Daniel Schepler
- [Coq-Club] setoid rewriting -- naive questions, Vadim Zaliva, 11/18/2014
- Re: [Coq-Club] setoid rewriting -- naive questions, Robbert Krebbers, 11/18/2014
- Re: [Coq-Club] setoid rewriting -- naive questions, Vadim Zaliva, 11/18/2014
- Re: [Coq-Club] setoid rewriting -- naive questions, Daniel Schepler, 11/18/2014
- Re: [Coq-Club] setoid rewriting -- naive questions, Vadim Zaliva, 11/19/2014
- Re: [Coq-Club] setoid rewriting -- naive questions, Daniel Schepler, 11/19/2014
- Re: [Coq-Club] setoid rewriting -- naive questions, Jonathan, 11/19/2014
- Re: [Coq-Club] setoid rewriting -- naive questions, Robbert Krebbers, 11/19/2014
- Re: [Coq-Club] setoid rewriting -- naive questions, Vadim Zaliva, 11/21/2014
- Re: [Coq-Club] setoid rewriting -- naive questions, Daniel Schepler, 11/21/2014
- Re: [Coq-Club] setoid rewriting -- naive questions, Vadim Zaliva, 11/22/2014
