coq-club - Re: [Coq-Club] setoid rewriting -- naive questions
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] setoid rewriting -- naive questions
  • Date: Tue, 18 Nov 2014 12:41:52 -0800
On Tue, Nov 18, 2014 at 11:58 AM, Vadim Zaliva <vzaliva AT cmu.edu> wrote:
> On Nov 18, 2014, at 11:33 , Robbert Krebbers <mailinglists AT robbertkrebbers.nl> wrote:
> You probably have forgotten to prove a Proper for Vcons.
Robbert,
Thanks! I also suspected that that might be the problem. How I should formulate
Propper instantiation in this case? My first naive attempt:
Instance Vcons_Proper:
    Proper (equiv ==> equiv) (Vcons).
did not work. Thanks!
I often define the equivalence on container types using an inductive with constructors which are directly of a Proper type:
(* crude reconstruction of what I need for the illustration *)
Inductive vector (A:Type) : nat -> Type :=
| vector_nil : vector A 0
| vector_cons : forall {n:nat}, A -> vector A n -> vector A (S n).
Class Equiv (A:Type) :=
eqv : A -> A -> Prop.
Infix "=" := eqv.
Notation "(=)" := eqv.
(* end crude reconstruction section *)
Require Import Morphisms.
Inductive vector_equiv (A:Type) `{Equiv A} : forall n:nat, Equiv (vector A n) :=
| vector_nil_proper : Proper (vector_equiv A 0) (@vector_nil A)
| vector_cons_proper : forall n:nat,
  Proper ((=) ==> vector_equiv A n ==> vector_equiv A (S n))
  (@vector_cons A n).
Existing Instance vector_equiv.
Existing Instance vector_nil_proper.
Existing Instance vector_cons_proper.
Daniel Schepler
