- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] setoid rewriting -- naive questions
- Date: Tue, 18 Nov 2014 18:08:19 -0800
On Nov 18, 2014, at 17:47 , Daniel Schepler <dschepler AT gmail.com> wrote:You appear to have two instances of Equiv B, which could be confusing things. My guess would be that you have something like `{Equiv B} `{Commutative f} where the second should be `{!Commutative f} instead. Also, I don't see any instances of Setoid B which could be useful in inferring Setoid (Vector.t B (S n)), which in turn would be useful for doing the rewriting.That said, when I tried it with a similar situation with only one Equiv B, and Setoid B in the context (and a registered instance of forall (A:Type) `{Setoid A} (n:nat), Setoid (Vector.t A n)), it still didn't work for me.
Thanks. I’ve fixed my lemma definition to avoid duplicate Equiv and added Setoid:
Lemma map2_setoid_comm {A} `{HS: Setoid B, !Commutative f}:
forall n (a b: vector A n),
(map2 f a b) = (map2 f b a).
Still as in your example the problem remains. It looks like we are stuck here.
Sincerely,
Vadim Zaliva
Vadim Zaliva
CMU ECE PhD student
Mobile: +1(510)220-1060
Skype: vzaliva
- [Coq-Club] setoid rewriting -- naive questions, Vadim Zaliva, 11/18/2014
- Re: [Coq-Club] setoid rewriting -- naive questions, Robbert Krebbers, 11/18/2014
- Re: [Coq-Club] setoid rewriting -- naive questions, Vadim Zaliva, 11/18/2014
- Re: [Coq-Club] setoid rewriting -- naive questions, Daniel Schepler, 11/18/2014
- Re: [Coq-Club] setoid rewriting -- naive questions, Vadim Zaliva, 11/19/2014
- Re: [Coq-Club] setoid rewriting -- naive questions, Daniel Schepler, 11/19/2014
- Re: [Coq-Club] setoid rewriting -- naive questions, Jonathan, 11/19/2014
- Re: [Coq-Club] setoid rewriting -- naive questions, Robbert Krebbers, 11/19/2014
- Re: [Coq-Club] setoid rewriting -- naive questions, Vadim Zaliva, 11/21/2014
- Re: [Coq-Club] setoid rewriting -- naive questions, Daniel Schepler, 11/21/2014
- Re: [Coq-Club] setoid rewriting -- naive questions, Vadim Zaliva, 11/22/2014
