- To: coq-club AT inria.fr
- Subject: [Coq-Club] Theorems about functions that produce option
- Date: Sun, 23 Nov 2014 10:50:46 -0300
Hi,
I am trying to write a theorem that says that a function produces Some when some conditions are met.
For example, suppose the dummy_function is defined like below
Definition dummy_function (n : nat) : option nat :=match n with| 0 => None| _ => Some 1end.
When I try
Theorem dummy_theorem1 : exists n : nat, dummy_function n = Some m.
Coq says
"The reference m was not found in the current environment."
So I tried
Theorem dummy_theorem1 : exists n : nat, dummy_function n = Some _.
In this case, Coq says
"Error: Cannot infer this placeholder."
After some attempts, I ended up with the following version
match dummy_function n with
| None => False
| Some _ => True
end.
I'd like to know if there is a better way to state a theorem like this.
Thanks,
Saulo Medeiros de Araujo
- [Coq-Club] Theorems about functions that produce option, Saulo Araujo, 11/23/2014
- Re: [Coq-Club] Theorems about functions that produce option, Arthur Azevedo de Amorim, 11/23/2014
- Re: [Coq-Club] Theorems about functions that produce option, Saulo Araujo, 11/23/2014
