- From: Arthur Azevedo de Amorim <arthur.aa AT gmail.com>
- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Theorems about functions that produce option
- Date: Sun, 23 Nov 2014 09:31:34 -0500
The problem with your first attempt is just that m was not bound
anywhere in your statement. You can fix it by saying something like
exists n m, dummy_function n = Some m
or
exists n, dummy_function n <> None
Usually, the first form will be more convenient to use.
Best
2014-11-23 8:50 GMT-05:00 Saulo Araujo
<saulo2 AT gmail.com>:
> Hi,
> I am trying to write a theorem that says that a function produces Some when
> some conditions are met.
> For example, suppose the dummy_function is defined like below
> Definition dummy_function (n : nat) : option nat :=
> match n with
> | 0 => None
> | _ => Some 1
> end.
> When I try
> Theorem dummy_theorem1 : exists n : nat, dummy_function n = Some m.
> Coq says
> "The reference m was not found in the current environment."
> So I tried
> Theorem dummy_theorem1 : exists n : nat, dummy_function n = Some _.
> In this case, Coq says
> "Error: Cannot infer this placeholder."
> After some attempts, I ended up with the following version
> match dummy_function n with
> | None => False
> | Some _ => True
> end.
> I'd like to know if there is a better way to state a theorem like this.
> Thanks,
> Saulo Medeiros de Araujo
- [Coq-Club] Theorems about functions that produce option, Saulo Araujo, 11/23/2014
- Re: [Coq-Club] Theorems about functions that produce option, Arthur Azevedo de Amorim, 11/23/2014
- Re: [Coq-Club] Theorems about functions that produce option, Saulo Araujo, 11/23/2014
