coq-club - Re: [Coq-Club] Theorems about functions that produce option
  • From: Arthur Azevedo de Amorim <arthur.aa AT gmail.com>
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Theorems about functions that produce option
  • Date: Sun, 23 Nov 2014 10:16:35 -0500
2014-11-23 9:55 GMT-05:00 Saulo Araujo
<saulo2 AT gmail.com>:
> Hi Artur,
> Thanks for your help. I have tried your suggestions and they indeed work.
> However, when I try to prove the theorem looks like I need to know what is
> the value of m.
> Here is the first version of the theorem and its proof:
> Theorem dummy_theorem1 : exists n : nat, match dummy_function n with
> | None => False
> | Some _ => True
> end.
> Proof.
> exists 1.
> reflexivity.
> Qed.
> Here is the second version:
> Theorem dummy_theorem2 : exists n m : nat, dummy_function n = Some m.
> Proof.
> exists 1.
> reflexivity.
> Qed.
> But Coq says
> "Tactic failure: The relation ex is not a declared reflexive relation. Maybe
> you need to require the Setoid library.Compilation output:"
> , probably because I did not specify the value of m.
> Coq accepts the proof below. But this requires that I know the specific
> value that is inside the option produce by (dummy_function 1).
> Proof.
> exists 1.
> exists 1.
> reflexivity.
> Qed.
For simple cases like that, eauto takes care of the job, and you don't
have to actually provide the value of m:
Lemma foo : exists n m, dummy_function n = Some m.
Proof.
exists 1. simpl. eauto.
Qed.
> Your second suggestion (exists n, dummy_function n <> None) is really nice
> but my problem is a little more complicated than dummy_function because my
> (real) theorem says something about the value that is inside the option
> produced by a function.
If you need to state lots of properties about the value that is
produced by your function, it's probably better to use a custom
inductive instead of combining them with lots of conjunctions and
existentials in an ad-hoc way:
Inductive foo :=
| Foo : forall n m, dummy_function n = Some m ->
P m ->
Q m ->
foo.
Best
> I tried to formulate my doubts using dummy_function as an example, but I
> simplified the problem too much.
> Thanks for your help!
> Saulo
> On Sun, Nov 23, 2014 at 11:31 AM, Arthur Azevedo de Amorim
> wrote:
>> The problem with your first attempt is just that m was not bound
>> anywhere in your statement. You can fix it by saying something like
>> or
>> Usually, the first form will be more convenient to use.
>> Best
>> 2014-11-23 8:50 GMT-05:00 Saulo Araujo
>> > Hi,
>> > I am trying to write a theorem that says that a function produces Some
>> > when
>> > some conditions are met.
>> > For example, suppose the dummy_function is defined like below
>> > Definition dummy_function (n : nat) : option nat :=
>> > match n with
>> > | 0 => None
>> > | _ => Some 1
>> > end.
>> > When I try
>> > Theorem dummy_theorem1 : exists n : nat, dummy_function n = Some m.
>> > Coq says
>> > "The reference m was not found in the current environment."
>> > So I tried
>> > Theorem dummy_theorem1 : exists n : nat, dummy_function n = Some _.
>> > In this case, Coq says
>> > "Error: Cannot infer this placeholder."
>> > After some attempts, I ended up with the following version
>> > | None => False
>> > | Some _ => True
>> > end.
>> > I'd like to know if there is a better way to state a theorem like this.
>> > Thanks,
>> > Saulo Medeiros de Araujo
