- To: Coq Club <coq-club AT inria.fr>
- Subject: [Coq-Club] idtac and other msgs in PG
- Date: Sat, 13 Dec 2014 11:26:49 -0500
For a while now I've been flipping back and forth between using PG and CoqIDE, mostly because for some reason PG no longer shows idtac messages (and other non-failure messages, such as from the Time command) in most cases. It only shows them when the message-producing tactic also solves the goal.
I'm wondering if anyone else has this issue with idtac in PG, or if I somehow have it misconfigured.
I'm using a recent trunk version of Coq and the most recent development version of PG (which is more than a year old).
-- Jonathan
- [Coq-Club] idtac and other msgs in PG, Jonathan, 12/13/2014
- Re: [Coq-Club] idtac and other msgs in PG, Pierre Courtieu, 12/15/2014
- Re: [Coq-Club] idtac and other msgs in PG, Jonathan, 12/15/2014
- Re: [Coq-Club] idtac and other msgs in PG, Enrico Tassi, 12/16/2014
- Re: [Coq-Club] idtac and other msgs in PG, Kazuhiko Sakaguchi, 12/15/2014
- Re: [Coq-Club] idtac and other msgs in PG, Pierre Courtieu, 12/16/2014
- Re: [Coq-Club] idtac and other msgs in PG, Jonathan, 12/16/2014
