coq-club - Re: [Coq-Club] idtac and other msgs in PG
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] idtac and other msgs in PG
  • Date: Tue, 16 Dec 2014 01:10:34 +0900
Hi Jonathan,
I solved a part of the issue by this code:
Require Import Coq.Strings.String.
Open Scope string.
Definition newline := String "010" "".
Definition line s := s ++ newline.
Definition show_pg s := String "254" s ++ String "255" "".
Goal False.
let s := eval vm_compute in (show_pg (line "foo" ++ line "bar")) in
idtac s.
Abort.
Regards,
Kazuhiko
2014-12-14 1:26 GMT+09:00 Jonathan
<jonikelee AT gmail.com>:
> For a while now I've been flipping back and forth between using PG and
> CoqIDE, mostly because for some reason PG no longer shows idtac messages
> (and other non-failure messages, such as from the Time command) in most
> cases. It only shows them when the message-producing tactic also solves the
> goal.
> I'm wondering if anyone else has this issue with idtac in PG, or if I
> somehow have it misconfigured.
> I'm using a recent trunk version of Coq and the most recent development
> version of PG (which is more than a year old).
> -- Jonathan
