coq-club - Re: [Coq-Club] idtac and other msgs in PG
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] idtac and other msgs in PG
  • Date: Mon, 15 Dec 2014 11:48:53 -0500
Interesting! So, as long as I start each idtac with that 254 string and end it with that 255 string, I can use idtac as usual to print arbitrary terms visibly in PG, even without converting them to strings first:
Goal False.
let s1 := eval vm_compute in (String "254" "") in
let s2 := eval vm_compute in (String "255" "") in
let x := constr:(1+1) in
idtac s1 "hello" "there" x s2.
Abort.
Thanks, Kazuhiko!
However, one thing I noticed is that this construction, when used in CoqIDE, not only doesn't print, it causes CoqIDE to hang. Of course, the motivation for its use is to not need CoqIDE for debugging tactics using idtac.
-- Jonathan
On 12/15/2014 11:10 AM, Kazuhiko Sakaguchi wrote:
Hi Jonathan,
I solved a part of the issue by this code:
Require Import Coq.Strings.String.
Open Scope string.
Definition newline := String "010" "".
Definition line s := s ++ newline.
Definition show_pg s := String "254" s ++ String "255" "".
Goal False.
let s := eval vm_compute in (show_pg (line "foo" ++ line "bar")) in
idtac s.
Abort.
Regards,
Kazuhiko
2014-12-14 1:26 GMT+09:00 Jonathan
<jonikelee AT gmail.com>:
For a while now I've been flipping back and forth between using PG and
CoqIDE, mostly because for some reason PG no longer shows idtac messages
(and other non-failure messages, such as from the Time command) in most
cases. It only shows them when the message-producing tactic also solves the
goal.
I'm wondering if anyone else has this issue with idtac in PG, or if I
somehow have it misconfigured.
I'm using a recent trunk version of Coq and the most recent development
version of PG (which is more than a year old).
-- Jonathan
