coq-club - Re: [Coq-Club] idtac and other msgs in PG
  • From: Pierre Courtieu <pierre.courtieu AT gmail.com>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] idtac and other msgs in PG
  • Date: Tue, 16 Dec 2014 13:27:06 +0000
Hi,
with coq trunk version this should be better now. With proofgeneral cvs (see below) version of today this should be even better.
Best regards,
Pierre
PS: From pg web page:
* CVS access
The Proof General CVS repository is available by anonymous CVS. Login with:
cvs -d :pserver:anon AT cvs.inf.ed.ac.uk:/disk/cvs/proofgen login
and use the password anon. Then you can check out the CVS with:
cvs -d :pserver:anon AT cvs.inf.ed.ac.uk:/disk/cvs/proofgen checkout ProofGeneral
Le Mon Dec 15 2014 at 17:15:41, Pierre Courtieu <pierre.courtieu AT gmail.com> a écrit :
:) nice dirty trick.
I am currently adapting coq output so that emacs will notice messages more accurately. Should be working tomorrow.
Best regards.
P.C.
Le Mon Dec 15 2014 at 5:11:12 PM, Kazuhiko Sakaguchi <pi8027 AT gmail.com> a écrit :
Hi Jonathan,
I solved a part of the issue by this code:
Require Import Coq.Strings.String.
Open Scope string.
Definition newline := String "010" "".
Definition line s := s ++ newline.
Definition show_pg s := String "254" s ++ String "255" "".
Goal False.
  let s := eval vm_compute in (show_pg (line "foo" ++ line "bar")) in
    idtac s.
Abort.
Regards,
Kazuhiko
2014-12-14 1:26 GMT+09:00 Jonathan <jonikelee AT gmail.com>:
> For a while now I've been flipping back and forth between using PG and
> CoqIDE, mostly because for some reason PG no longer shows idtac messages
> (and other non-failure messages, such as from the Time command) in most
> cases.  It only shows them when the message-producing tactic also solves the
> goal.
> I'm wondering if anyone else has this issue with idtac in PG, or if I
> somehow have it misconfigured.
> I'm using a recent trunk version of Coq and the most recent development
> version of PG (which is more than a year old).
> -- Jonathan
