RE: [Coq-Club] Type Class instance resolution stops working after adding type specification to definition
- From: "Soegtrop, Michael" <michael.soegtrop AT intel.com>
- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: RE: [Coq-Club] Type Class instance resolution stops working after adding type specification to definition
- Date: Wed, 17 Dec 2014 08:58:01 +0000
- Accept-language: de-DE, en-US
Dear Coq users,
one note on this: in case the type t2 is defined directly and not computed by
the fixpoint on the structure definition, the Type Class mechanism does work.
Definition t2 := (bool * (bool * unit) * (bool * (bool * unit) * unit))%type.
Example v1 := (true, (false, tt), (true, (false, tt), tt)).
Example v2 : t2 := (true, (false, tt), (true, (true, tt), tt)).
Eval compute in eqb v1 v2. (* => false *)
Eval compute in eqb v1 v1. (* => true *)
Example v3 : t2 := (true, (false, tt), (true, (false, tt), tt)).
Eval compute in eqb v3 v2. (* => false *)
Only if t2 is computed by the fixpoint given in my first post, it doesn't
work.
= (let (eqb, _) := ?257 in eqb)
: bool
Is this a bug in the Type Class mechanism?
Best regards,
Michael
- [Coq-Club] Type Class instance resolution stops working after adding type specification to definition, michael.soegtrop, 12/16/2014
- RE: [Coq-Club] Type Class instance resolution stops working after adding type specification to definition, Soegtrop, Michael, 12/17/2014
- Re: [Coq-Club] Type Class instance resolution stops working after adding type specification to definition, Amin Timany, 12/17/2014
- Re: [Coq-Club] Type Class instance resolution stops working after adding type specification to definition, Amin Timany, 12/22/2014
- Re: [Coq-Club] Type Class instance resolution stops working after adding type specification to definition, Jonathan Leivent, 12/22/2014
