coq-club - Re: [Coq-Club] Type Class instance resolution stops working after adding type specification to definition
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Type Class instance resolution stops working after adding type specification to definition
  • Date: Wed, 17 Dec 2014 14:15:33 +0100
Dear Micheal,
In coq, type class resolution is done in a way very similar to eauto, i.e.,
"typeclasses eauto”. In other words, coq tries to apply registered instances
repeatedly to resolve an instance. Debug information here shows that in this
case type class resolution gets stuck on the term:
(EqDec
((fix type (k : Kind) : Type :=
match k with
| Bool => bool
| Struct list =>
let fix typeaux (l : list (string * Kind)) :
Type :=
match l with
| nil => unit
| (_, elem) :: tail =>
(type elem * typeaux tail)%type
end in
typeaux list
end) ex1))
I don’t know if this is the intended behavior or a bug as "typeclasses eauto"
seems to be able to simplify t2 and ext2 but not ext1 !?
To see details run the following code after the end of you original input.
Typeclasses eauto := debug 5. (* enabling debug mode for typeclasses eauto
tactic and setting the search depth to 5 *)
Instance t2_dec : EqDec t2.
Fail typeclasses eauto. (* Check out debug message *)
cbv.
typeclasses eauto. (* this solves the goal *)
Abort.
Instance test_dec : EqDec ((((bool * (bool * unit) * (bool * (bool * unit) *
unit)) * (bool * (bool * unit) * (bool * (bool * unit) * unit))) * ((bool *
(bool * unit) * (bool * (bool * unit) * unit)) * (bool * (bool * unit) *
(bool * (bool * unit) * unit)))))%type.
Fail typeclasses eauto. (* Fails as search does not go deep enough.
increasing the depth "5" in command "Typeclasses eauto := debug 5." above
will solve this problem *)
Typeclasses eauto := debug 7.
Abort.
This code also shows that even if typeclasses eauto would have been able to
resolve such goals as EqDec t2, it would fail on big enough terms. The better
way would be to define “Instance type_of_kind_eqb (k : Kind) : EqDec (type
k).” explicitly. Here I have done this. To simplify proofs and definitions I
have stopped coq from generating incorrect (inferred) induction/recursion
schemes and have provided Kind_rect, Kind_rec and Kind_ind explicitly.
Require Import String.
Require Import List.
Open Scope string_scope.
Unset Elimination Schemes.
Inductive Kind: Set :=
| Bool: Kind
| Struct: list (string * Kind) -> Kind.
Theorem Kind_rect : forall P : Kind -> Type,
P Bool ->
P (Struct nil) ->
(forall (a : string * Kind) (l : list (string * Kind)), P (snd a) -> P
(Struct l) -> P (Struct (a :: l))) ->
forall k : Kind, P k.
Proof.
intros P PB PN PL k.
refine (
(fix rect m : P m :=
match m with
| Bool => PB
| Struct list => let fix rectaux l : P (Struct l) :=
match l with
| nil => PN
| h::tail => PL _ _ (rect (snd h)) (rectaux
tail)
end in rectaux list
end
) k).
Defined.
Theorem Kind_rec : forall P : Kind -> Set,
P Bool ->
P (Struct nil) ->
Proof.
intros; apply Kind_rect; trivial.
Defined.
Theorem Kind_ind : forall P : Kind -> Prop,
P Bool ->
P (Struct nil) ->
Proof.
Defined.
Set Elimination Schemes.
Fixpoint type (k : Kind) : Type :=
match k with
| Bool => bool
| Struct list => let fix typeaux l : Type :=
match l with
| nil => unit
| (name,elem)::tail => ((type elem)*(typeaux tail))%type
end in typeaux list
end.
Example ex1 := Struct (("a",Bool)::("b",Bool)::nil).
Example ex2 := Struct (("s",ex1)::("t",ex1)::nil).
Example t2 := type ex2.
Eval compute in t2.
(* = (bool * (bool * unit) * (bool * (bool * unit) * unit))%type : Type *)
Class EqDec (A : Type) := {
eqb : A -> A -> bool ;
eqb_leibniz : forall x y, eqb x y = true -> x = y
Instance unit_EqDec : EqDec unit := {
eqb x y := true;
eqb_leibniz x y H := match x, y return x = y with tt, tt => eq_refl tt end
Instance bool_EqDec : EqDec bool := {
eqb x y := Bool.eqb x y
Proof. intros; destruct x; destruct y; try reflexivity; try inversion H.
Defined.
Instance prod_eqb {A B : Type} (EA : EqDec A) (EB : EqDec B) : EqDec (A *
B) := {
eqb x y := match x, y with
| (la, ra), (lb, rb) => andb (eqb la lb) (eqb ra rb)
end
Proof.
intros. destruct x. destruct y.
assert(H0:=Bool.Is_true_eq_left _ H).
assert(H1:=Bool.andb_prop_elim _ _ H0).
inversion H1 as [H2 H3].
assert(H4:=Bool.Is_true_eq_true _ H2).
assert(H5:=Bool.Is_true_eq_true _ H3).
assert(H6:=eqb_leibniz _ _ H4).
assert(H7:=eqb_leibniz _ _ H5).
subst. reflexivity.
Defined.
Example eqdec1 := (true,(false,tt)).
Example eqdec2 := (true,(true,tt)).
Eval compute in eqb eqdec1 eqdec1.
Eval compute in eqb eqdec1 eqdec2.
Example v1 := (true, (false, tt), (true, (false, tt), tt)).
Example v2 : t2 := (true, (false, tt), (true, (true, tt), tt)).
Eval compute in eqb v1 v2. (* => false *)
Eval compute in eqb v1 v1. (* => true *)
Example v3 : t2 := (true, (false, tt), (true, (false, tt), tt)).
Eval compute in eqb v3 v2. (* =>
= (let (eqb, _) := ?257 in eqb)
: bool
Instance type_of_kind_eqb (k : Kind) : EqDec (type k).
Proof.
induction k as [| |a k]; [| | destruct a as [str elm]]; typeclasses eauto.
Defined.
= false
: bool
Regards,
Amin
> On 17 Dec 2014, at 09:58, Soegtrop, Michael
> <michael.soegtrop AT intel.com>
> wrote:
> Dear Coq users,
> one note on this: in case the type t2 is defined directly and not computed
> by the fixpoint on the structure definition, the Type Class mechanism does
> work.
> Definition t2 := (bool * (bool * unit) * (bool * (bool * unit) *
> unit))%type.
> Eval compute in eqb v3 v2. (* => false *)
> Only if t2 is computed by the fixpoint given in my first post, it doesn't
> work.
> : bool
> Is this a bug in the Type Class mechanism?
> Best regards,
> Michael
