RE: [Coq-Club] Type Class instance resolution stops working after adding type specification to definition
- From: "Soegtrop, Michael" <michael.soegtrop AT intel.com>
- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: RE: [Coq-Club] Type Class instance resolution stops working after adding type specification to definition
- Date: Wed, 17 Dec 2014 15:09:01 +0000
- Accept-language: de-DE, en-US
Dear Amin,
thanks a lot for your very detailed answer! It contains a lot of interesting
ideas/hints/pointers. But it also brings up a few more questions:
1.) Partly this seems to be a problem of simplification of fixpoints. The
type terms generated by the fixpoint are huge and ugly, but when I do a
compute on them, they become very small and nice. One thing I couldn't find
in Gallina is a function to do reductions on a term. I know it should never
make a logical difference, but especially with large developments, it could
make a significant performance difference, if I could do reductions of terms
at Gallina level. I also think that it would solve the problem here (except
for the nesting depht problem).
2.) Is the Type Class mechanism considered to be part of Gallina or outside
of it at the vernacular / tactics level? In the first case, does the
implementation of Type Class instance search with eauto mean that the Type
Class feature breaks the parametricity feature of Gallina?
3.) Is the instance search an easily decidable problem?
Best regards,
Michael
- [Coq-Club] Type Class instance resolution stops working after adding type specification to definition, michael.soegtrop, 12/16/2014
- RE: [Coq-Club] Type Class instance resolution stops working after adding type specification to definition, Soegtrop, Michael, 12/17/2014
- Re: [Coq-Club] Type Class instance resolution stops working after adding type specification to definition, Amin Timany, 12/17/2014
- Re: [Coq-Club] Type Class instance resolution stops working after adding type specification to definition, Amin Timany, 12/22/2014
- Re: [Coq-Club] Type Class instance resolution stops working after adding type specification to definition, Jonathan Leivent, 12/22/2014
