coq-club - Re: [Coq-Club] Type Class instance resolution stops working after adding type specification to definition
  • To: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Type Class instance resolution stops working after adding type specification to definition
  • Date: Mon, 22 Dec 2014 21:19:50 -0500
The answer to the question of parametricity is that type class resolution is done at type *inference* time, not type *checking* time.  Thus, like notations and the tactics-in-terms of trunk, it has no impact on parametricity.  (Another way of seeing this is that typeclasses live outside the kernel, like tactics and notations.)
-Jason
On Dec 22, 2014 12:30 PM, "Jonathan Leivent" <jonikelee AT gmail.com> wrote:
On 12/22/2014 12:12 PM, Amin Timany wrote:
In gallina, you can use the following command:
Definition x := Eval tac in y.
Where tac is a computation tactic, e.g., simpl, cbv, compute, etc. Unfortunately, this construction is only at the level of gallina and not terms. So,
Definition x := z (Eval tac in y).
will generate a parsing error!
But you can do this:
Ltac reduce term :=
  let x := eval compute in term in exact x.
Variable P : nat -> Prop.
Definition foo := P (1+2+3).
Print foo. (* P (1 + 2 + 3) *)
Definition bar := P $(reduce (1+2+3))$.
Print bar. (* P 6 *)
-- Jonathan
