- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Beginner question
- Date: Thu, 18 Dec 2014 10:57:04 -0500
Try destruct objEq obj obj'. Then you should get two goals, one where H has type true = false (which you can then invert) and one where H had the type of the goal.
-akh
On Dec 18, 2014 9:47 AM, "Saulo Araujo" <saulo2 AT gmail.com> wrote:
Hi,I am trying to prove the following very simple theorem:Require Import Arith.Require Import List. Import ListNotations.Inductive OBJ := Obj : nat -> OBJ.Definition objEq obj obj' := let 'Obj id := objin let 'Obj id' := obj'in beq_nat id id'.Fixpoint containsObj objs obj := match objs with| [] => false| obj' :: objs' => if objEq obj' obj then true else containsObj objs' objend.Theorem containsObj_t1 :forall (obj obj' : OBJ) (objs : list OBJ),containsObj (obj :: objs) obj' = false -> containsObj objs obj' = false.When I tryProof.intros.simpl in H.Qed.Coq shows that H is(if objEq obj obj' then true else containsObj objs obj') = falseFrom where I believe it is safe to say that containsObj objs obj' = false.But no matter what I try, I cannot convince Coq that containsObj objs obj' = false :)Any suggestions?Thanks in advance,Saulo
- [Coq-Club] Beginner question, Saulo Araujo, 12/18/2014
- Re: [Coq-Club] Beginner question, Andrew Hirsch, 12/18/2014
- Re: [Coq-Club] Beginner question, Saulo Araujo, 12/18/2014
- Re: [Coq-Club] Beginner question, Jean-Francois Monin, 12/18/2014
