coq-club - Re: [Coq-Club] Beginner question
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Beginner question
  • Date: Thu, 18 Dec 2014 13:05:37 -0300
Thans a lot Andrew. It works :
Theorem containsObj_t1 :
  forall (obj obj' : OBJ) (objs : list OBJ),
  containsObj (obj :: objs) obj' = false -> containsObj objs obj' = false.
Proof.
  intros.
  simpl in H.
  destruct (objEq obj obj').
  inversion H.
  trivial.
Qed.
Now I am going to try to understand what inversion does. Thanks a lot!
On Thu, Dec 18, 2014 at 12:57 PM, Andrew Hirsch <akhirsch AT cs.cornell.edu> wrote:
Try destruct objEq obj obj'. Then you should get two goals, one where H has type true = false (which you can then invert) and one where H had the type of the goal.
-akh
On Dec 18, 2014 9:47 AM, "Saulo Araujo" <saulo2 AT gmail.com> wrote:
Hi,
I am trying to prove the following very simple theorem:
Require Import Arith.
Require Import List. Import ListNotations.
Inductive OBJ := Obj : nat -> OBJ.
Definition objEq obj obj' := let 'Obj id := obj
  in let 'Obj id' := obj'
  in beq_nat id id'.
Fixpoint containsObj objs obj := match objs with
    | [] => false
    | obj' :: objs' => if objEq obj' obj then true else containsObj objs' obj
  end.
When I try
Proof.
  intros.
  simpl in H.
Qed.
Coq shows that H is
(if objEq obj obj' then true else containsObj objs obj') = false
From where I believe it is safe to say that containsObj objs obj' = false.
But no matter what I try, I cannot convince Coq that containsObj objs obj' = false :)
Any suggestions?
Thanks in advance,
Saulo
