- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Beginner question
- Date: Thu, 18 Dec 2014 13:57:26 -0300
Hi Andrew,
It works indeed. I got a little confused after so many Coq hours :)
Thanks a lot!
Saulo
On Thu, Dec 18, 2014 at 1:51 PM, Andrew Hirsch <akhirsch AT cs.cornell.edu> wrote:
The same trick seems to work for me. I get two goals, true = false (with H : true = false, inversion H), and false = false (trivial). Here's the script I have:Theorem containsObj_t2 :forall (obj obj' : OBJ) (objs : list OBJ),containsObj (obj :: objs) obj' = false ->objEq obj obj' = false.Proof.intros; simpl in H.destruct (objEq obj obj').inversion H.trivial.Qed.On Thu, Dec 18, 2014 at 10:23 AM, Saulo Araujo <saulo2 AT gmail.com> wrote:Andrew,Maybe you could help me with this another very simple theorem:Theorem containsObj_t2 :forall (obj obj' : OBJ) (objs : list OBJ),containsObj (obj :: objs) obj' = false -> objEq obj obj' = false.Proof.intros.simpl in H.Qed.Just like in the other theorem, Coq says that H is(if objEq obj obj' then true else containsObj objs obj') = falseAgain, I think is safe to say that objEq obj obj' = false but I cannot convince Coq about that. I tried destruct and inversion as in your last suggestion but this time it does not do the tricky. Sorry about asking such beginner questions but I am really stuck,Thanks in advance,SauloOn Thu, Dec 18, 2014 at 1:05 PM, Saulo Araujo <saulo2 AT gmail.com> wrote:Thans a lot Andrew. It works :Theorem containsObj_t1 :forall (obj obj' : OBJ) (objs : list OBJ),containsObj (obj :: objs) obj' = false -> containsObj objs obj' = false.Proof.intros.simpl in H.destruct (objEq obj obj').inversion H.trivial.Qed.Now I am going to try to understand what inversion does. Thanks a lot!On Thu, Dec 18, 2014 at 12:57 PM, Andrew Hirsch <akhirsch AT cs.cornell.edu> wrote:Try destruct objEq obj obj'. Then you should get two goals, one where H has type true = false (which you can then invert) and one where H had the type of the goal.
-akh
On Dec 18, 2014 9:47 AM, "Saulo Araujo" <saulo2 AT gmail.com> wrote:Hi,I am trying to prove the following very simple theorem:Require Import Arith.Require Import List. Import ListNotations.Inductive OBJ := Obj : nat -> OBJ.Definition objEq obj obj' := let 'Obj id := objin let 'Obj id' := obj'in beq_nat id id'.Fixpoint containsObj objs obj := match objs with| [] => false| obj' :: objs' => if objEq obj' obj then true else containsObj objs' objend.Theorem containsObj_t1 :forall (obj obj' : OBJ) (objs : list OBJ),containsObj (obj :: objs) obj' = false -> containsObj objs obj' = false.When I tryProof.intros.simpl in H.Qed.Coq shows that H is(if objEq obj obj' then true else containsObj objs obj') = falseFrom where I believe it is safe to say that containsObj objs obj' = false.But no matter what I try, I cannot convince Coq that containsObj objs obj' = false :)Any suggestions?Thanks in advance,Saulo
- [Coq-Club] Beginner question, Saulo Araujo, 12/18/2014
- Re: [Coq-Club] Beginner question, Andrew Hirsch, 12/18/2014
- Re: [Coq-Club] Beginner question, Saulo Araujo, 12/18/2014
- Re: [Coq-Club] Beginner question, Jean-Francois Monin, 12/18/2014
