- From: Jean-Francois Monin <jean-francois.monin AT imag.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Beginner question
- Date: Thu, 18 Dec 2014 18:18:52 +0100
- Mailscanner-null-check: 1419527932.67637@WoZdMrvwLjewa7DFrvFjKw
No need for inversion in the second theorem :
true = false |- true = false
holds just by assumption (or trivial).
Theorem containsObj_t2 :
forall (obj obj' : OBJ) (objs : list OBJ),
containsObj (obj :: objs) obj' = false -> objEq obj obj' = false.
Proof.
intros * e.
simpl in e.
destruct (objEq obj obj').
trivial.
trivial.
Qed.
No need for inversion in the first theorem as well :
after an additional destruct (containsObj objs obj'), you get the same
situation.
Theorem containsObj_t1 :
containsObj (obj :: objs) obj' = false -> containsObj objs obj' = false.
Proof.
intros * e.
simpl in e.
destruct (containsObj objs obj').
trivial.
trivial.
trivial.
Qed.
More generally, looking at "small inversions" in the litterature
may provide you simple intuitions on what inversion means.
JFM
On Thu, Dec 18, 2014 at 10:51:55AM -0600, Andrew Hirsch wrote:
> The same trick seems to work for me. I get two goals, true = false (with
> H
> : true = false, inversion H), and false = false (trivial). Here's the
> script I have:
> Proof.
> intros; simpl in H.
> inversion H.
> trivial.
> Qed.
> On Thu, Dec 18, 2014 at 10:23 AM, Saulo Araujo
> <[1]saulo2 AT gmail.com>
> wrote:
> Andrew,
> Maybe you could help me with this another very simple theorem:
> Proof.
> intros.
> simpl in H.
> Qed.
> Just like in the other theorem, Coq says that H is
> (if objEq obj obj' then true else containsObj objs obj') = false
> Again, I think is safe to say that objEq obj obj' = false but I cannot
> convince Coq about that. I tried destruct and inversion as in your last
> suggestion but this time it does not do the tricky. Sorry about asking
> such beginner questions but I am really stuck,
> Thanks in advance,
> Saulo
> On Thu, Dec 18, 2014 at 1:05 PM, Saulo Araujo
> <[2]saulo2 AT gmail.com>
> wrote:
> Thans a lot Andrew. It works :
> false.
> Proof.
> intros.
> simpl in H.
> inversion H.
> trivial.
> Qed.
> Now I am going to try to understand what inversion does. Thanks a
> lot!
> On Thu, Dec 18, 2014 at 12:57 PM, Andrew Hirsch
> <[3]akhirsch AT cs.cornell.edu>
> wrote:
> Try destruct objEq obj obj'. Then you should get two goals, one
> where H has type true = false (which you can then invert) and one
> where H had the type of the goal.
> -akh
> On Dec 18, 2014 9:47 AM, "Saulo Araujo"
> <[4]saulo2 AT gmail.com>
> wrote:
> Hi,
> I am trying to prove the following very simple theorem:
> Require Import Arith.
> Require Import List. Import ListNotations.
> Inductive OBJ := Obj : nat -> OBJ.
> Definition objEq obj obj' := let 'Obj id := obj
> in let 'Obj id' := obj'
> in beq_nat id id'.
> Fixpoint containsObj objs obj := match objs with
> | [] => false
> | obj' :: objs' => if objEq obj' obj then true else
> containsObj objs' obj
> end.
> = false.
> When I try
> Proof.
> intros.
> simpl in H.
> Qed.
> Coq shows that H is
> From where I believe it is safe to say that containsObj objs obj'
> = false.
> But no matter what I try, I cannot convince Coq that containsObj
> objs obj' = false :)
> Any suggestions?
> Thanks in advance,
> Saulo
Jean-Francois Monin
- [Coq-Club] Beginner question, Saulo Araujo, 12/18/2014
- Re: [Coq-Club] Beginner question, Andrew Hirsch, 12/18/2014
- Re: [Coq-Club] Beginner question, Saulo Araujo, 12/18/2014
- Re: [Coq-Club] Beginner question, Jean-Francois Monin, 12/18/2014
