- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] heterogeneous tuple element function
- Date: Thu, 15 Jan 2015 18:33:24 -0500
On 01/15/2015 06:13 PM, Vilhelm Sjöberg wrote:
On 2015-01-15 17:41, Jonathan Leivent wrote:
I would like to write a recursive function that takes 3 arguments: an element index (0-based), a count of elements, and a heterogeneous tuple containing (usually) that many elements - and have it return the indexed element of the tuple if it exists. If the tuple doesn't contain the right number of elements, I don't care what the function does, and I don't want to provide a proof that the tuple contains the right number of elements. The index < count - and if not, then I don't care what the function does.
Notes: the tuple arg will be strictly right-associated. If count =1, then the third arg is just an arbitrarily-typed singleton, and is the result itself. If count>1, then the last element is the snd of the last pair, while all previous elements are the fst of some pair.
I know how to do this when the container is homogeneous, as with lists or vectors - but not with hetero tuples. I don't even know how to write the type of the function in this case.
Also, I think I may have seen the solution to this somewhere - but don't remember where... Was it in CPDT somewhere?
Any clues on how to write this function?
I guess your problem is that you can't write down the type "some tuple with n components (of arbitrary types)". However, you can do something similar, where instead of just the number of tuple components, you give a list of the types in it.
The below code differs a little from your definition of right-associated tuple, because I made all the tuples end with a unit value for simplicitly.
There are some very similar functions in CPDT (http://adam.chlipala.net/cpdt/html/DataStruct.html), but I can't find this exact one.
Require Import List.
Fixpoint tupleType (ts : list Set) : Set :=
match ts with
| nil => unit
| t::ts => t * tupleType ts
end %type.
Fixpoint get (ts : list Set) : forall (i:nat), tupleType ts -> nth i
ts unit :=
match ts return forall (i:nat), tupleType ts -> nth i ts unit with
| nil => fun i v => match i with 0 => tt | S _ => tt end
| t::ts => fun i => match i
with
| 0 => fun v => fst v
| S j => fun v => get ts j (snd v)
end
end.
Eval compute in
get (nat::bool::nat::nil) 2 (1,(true,(42,tt))). (* = 42 *)
Vilhelm
That does look familiar. However, how to get 'get' to infer the ts arg from the tuple? As this doesn't work:
get _ 2 (1, (true, (42, tt))).
-- Jonathan
- [Coq-Club] heterogeneous tuple element function, Jonathan Leivent, 01/15/2015
- Re: [Coq-Club] heterogeneous tuple element function, Vilhelm Sjöberg, 01/16/2015
- Re: [Coq-Club] heterogeneous tuple element function, Jonathan Leivent, 01/16/2015
- Re: [Coq-Club] heterogeneous tuple element function, flicky frans, 01/16/2015
- Re: [Coq-Club] heterogeneous tuple element function, Jason Gross, 01/17/2015
- Re: [Coq-Club] heterogeneous tuple element function, Jonathan Leivent, 01/17/2015
- Re: [Coq-Club] heterogeneous tuple element function, Jason Gross, 01/18/2015
- Re: [Coq-Club] heterogeneous tuple element function, Jonathan Leivent, 01/18/2015
