coq-club - Re: [Coq-Club] heterogeneous tuple element function
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] heterogeneous tuple element function
  • Date: Fri, 16 Jan 2015 11:40:14 -0500
On 01/15/2015 07:02 PM, Vilhelm Sjöberg wrote:
On 2015-01-15 18:33, Jonathan Leivent wrote:
That does look familiar. However, how to get 'get' to infer the ts arg from the tuple? As this doesn't work:
get _ 2 (1, (true, (42, tt))).
One way is to use typeclasses to infer this. The below code is inspired by the Data.Typeable class in Haskell; I'm not sure if there already is some existing similar framework in Coq.
Class Typeable (T : Set) := {
getCode : list Set;
getCode_spec : T = tupleType getCode
Instance TypableUnit : Typeable unit :=
Build_Typeable unit nil eq_refl.
Instance TypeablePair (a b : Set) (c : Typeable b) : Typeable (a*b).
apply (Build_Typeable (a*b) (a::getCode)).
simpl. rewrite <- getCode_spec.
reflexivity.
Defined.
Definition cast {a b : Set} (p: a=b) (x: a) : b :=
match p in _=b return b with eq_refl => x end.
Definition get' {a:Set} {c: Typeable a} (i:nat) (v : a) :=
get getCode i (cast getCode_spec v).
Eval compute in
get' 2 (1,(true,(42,tt))). (* = 42 *)
Vilhelm
This reminds me that I really need to learn me some typeclasses :-[
Can this be simplified by using a typeclass to overload get on pairs vs. every other type - and by doing so, ditch the tupleType completely?
-- Jonathan
