RE: [Coq-Club] Term classification in ltac: has_var / is_constr / term complexity measure
- From: "Soegtrop, Michael" <michael.soegtrop AT intel.com>
- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: RE: [Coq-Club] Term classification in ltac: has_var / is_constr / term complexity measure
- Date: Thu, 2 Apr 2015 08:32:10 +0000
- Accept-language: de-DE, en-US
Dear Jonathan,
I am making some use of 8.5 features, so if the 8.5 version has a cleaner
result, I would use the 8.5 version. But I am also curious to see how you
solved it in 8.4.
Regarding context searches: I am interested in proof automation performance
and context searches with unspecific search patterns and heavy follow up
tactics have a bad impact on performance. But context searches with
restrictive patterns or lightweight follow up tactics or properly gated
heavier tactics are fine. On the other hand everything which leads to good
search tree pruning or more stable proof search is usually worth the effort.
What counts is ease of use, stability and the final performance. I am quite
pragmatic in reaching these goals.
For the time being I think I will go with Ltac as far as possible. Meanwhile
I am quite happy with it. I try to delay plugin development until sometime
later when my project grows larger.
Here is the final "IsLiteralTerm" tactic which is based on your is_ctor
tactic (called IsCtorSym below).
(* Check if the given term is an inductive type *)
Ltac IsInductiveType type :=
let H:=fresh in
(* Using type as a precondition allows us to get a value of the type during
the proof of the assert *)
assert (type -> True) as H by (
(* val is a opaque value of type 'type' *)
intros val;
(* See if val can be destructed, if so solve the goal *)
destruct val; exact I
(* clear the hypothesis generated by the assert *)
clear H.
(* Check if a complete term contains only constructors and inductive type
names like a polymorphic list type argument.
This includes numbers, lists of numbers, strings, booleans, ... *)
Ltac IsLiteralTerm term := lazymatch term with
| ?H ?A1 =>
(* Debug idtac "f2" H A1; *)
IsLiteralTerm H;
IsLiteralTerm A1
| ?H =>
(* Debug idtac "f1" H; *)
first [ IsCtorSym H | IsInductiveType H ]
end.
Best regards,
Michael
- RE: [Coq-Club] Term classification in ltac: has_var / is_constr / term complexity measure, Soegtrop, Michael, 04/01/2015
- Re: [Coq-Club] Term classification in ltac: has_var / is_constr / term complexity measure, Jonathan Leivent, 04/01/2015
- RE: [Coq-Club] Term classification in ltac: has_var / is_constr / term complexity measure, Soegtrop, Michael, 04/02/2015
- Re: [Coq-Club] Term classification in ltac: has_var / is_constr / term complexity measure, Jonathan Leivent, 04/02/2015
- Re: [Coq-Club] Term classification in ltac: has_var / is_constr / term complexity measure, Jonathan Leivent, 04/04/2015
- [Coq-Club] Type:Type and turning of universe consistency check, Erik Palmgren, 04/12/2015
- Re: [Coq-Club] Type:Type and turning of universe consistency check, Jason Gross, 04/12/2015
- Re: [Coq-Club] Type:Type and turning of universe consistency check, Erik Palmgren, 04/12/2015
- Re: [Coq-Club] Type:Type and turning of universe consistency check, Vladimir Voevodsky, 04/13/2015
